CID error
Well i have a question, could the CID cause my CCC to boot in french and have Bluetooth stop working until i restart the CCC or I just leave it alone then it just restarts by itself after a couple minutes and fixes itself. This seems to happen about once a week, and the only error code I get is CID malfunction. Is the CID in charge of anything else other then just being a screen, does it house some settings or language profiles? any help would be appreciated.
Bluetooth modul gone bad , common faliur.
Originally Posted by BenAnd
(Post 1577781)
Hi
Yes , it can make all kinds of faulty codes , try and disconnect the Bluetooth modul ( ULF/TCU ) , but remeber to make a loop on the LVDS cabel ( optical fiber cabel ) at the LVDS connector by the modul ( if you have Logic7,TV modul ,HUD etc. you will loose the sound if you not make the loop ) |
(Post 1577807)
Hi
Yes , it can make all kinds of faulty codes , try and disconnect the Bluetooth modul ( ULF/TCU ) , but remeber to make a loop on the LVDS cabel ( optical fiber cabel ) at the LVDS connector by the modul ( if you have Logic7,TV modul ,HUD etc. you will loose the sound if you not make the loop ) Thank for the help |
