Chrome Trim
Old Jan 21, 2008 | 05:39 PM
subarashi's Avatar
My Ride: 2005 545i E60 Orient Blau Metallic Premium, NAV, Winter Package, Heads Up Display, Logic 7 Audio, AngeliBright Upgrade [White], M5 Body Kit, M Embroidered Seats
Hello all:
So my 2005 545i has had a strange problem. My driver side Chrome Trim molding [on the bottom of the window pane], is starting to "rise" from it's tape and no longer "sits" on the door frame properly. I wouldn't really care except for when you look at the side profile of the vehicle, the trim on the front door is on a whole different horizontal level than the one on the passenger door right behind it! Looks a little weird! If I press down on the drivers chrome trim, it falls back into proper place but this only lasts for a few hours and then it pops back up.
Anyone else experience this issue? Is the trim easy to get and change out as a DIY? Ive seen you write up shadow trim change outs but what about replacing an original chrome piece????
Old Jan 21, 2008 | 05:43 PM
kscarrol's Avatar
My Ride: E90 M3
Model Year: 2011
Unless you've clocked too many miles, you should be under warranty. Drop by the dealer and have them fix it... Never had this sort of problem on my old 545.
Old Jan 21, 2008 | 06:42 PM
CWS530's Avatar
Originally Posted by subarashi' post='521015' date='Jan 21 2008, 08:39 PM
Hello all:
Same thing happened on my new 530i a couple of months ago, after I'd had it about five months. It was happening on both the driver and passenger side fronts. My SA said it was an adhesive issue that he'd seen a few times and replaced both, in about five minutes while I waited, under warranty.
Old Jan 21, 2008 | 06:44 PM
sweeet's Avatar
i have same exact problem, passenger door too...which i brough to dealer and they "fixed". this lasted about a week...
anyone have dealer switch out chrome trim for shadowline? how much???
Old Jan 22, 2008 | 10:54 AM
Annraoi's Avatar
Yip -- Me Too
This started on my 2005 520i last year. Did nothing about it as I traded for LCI 520d in January.
Old Jan 22, 2008 | 11:59 AM
southgate's Avatar
mine dosent have the chrome trim but i was thinking of getting it
Old Jan 22, 2008 | 12:05 PM
IrishEyes's Avatar
My Ride: Collected Sept 2009 - BMW E90 M3, Silverstone II, Novillo Black leather, 19" M Double-Spoke alloys, High Beam Assist, Electronic Damper Control, Voice Control, PDC, USB, DAB, High Gloss Shadowline, Sliding armrest, Trim Finishing in aluminium grey.
Nearly every e60 I've seen suffers from that. My two did as well.
Old Jan 22, 2008 | 12:37 PM
hondik's Avatar
My Ride: E61 CarbonBlack 535d, Ventilated and Heated Comfort Seats with Massage in Black Nasca Leather, Dark Poplar Wood, Professional Navi, Folding Rear Seats, Load Through, Advanced Remote, PDC, Bluetooth, Dimming and folding Mirrors, Bi-Xenons, Hi-Fi, Tinted
Yeah exactly, every chrome trim E60 has it. Easiest is having the dealer fix it, it's 2minutes work. Or if you can't wait, do it yourself - lift the trim line and fix the sticky tape inside/beneath, it comes usually badly sat in. How easy is that. I was having this problem for about a month or two still thinking about buying a glue but it wasn't necessary. 8.000Kms past and it still holds like new.
Old Jan 24, 2008 | 04:57 AM
subarashi's Avatar
Thanks for all the replies...the interesting thing is if I apply a little pressure, the trim sits back into place [almost like the foam sticky adhesive underneath it has enough play to let that happen]. Unforutnately, the effect doesn't last.
I have about 60K miles on my 05 545i so I think that's probably what it is. Will have my dealer address it on the next visit down there. Gawd I love this forum!! Thanks all....
Kaane
Mar 15, 2022 05:16 AM
Vman33
Mar 14, 2022 04:43 AM
CHRGRS_BMW
38
Sep 1, 2016 09:39 AM
DetailersDomain
Detailing Forum
Sep 22, 2015 03:59 PM
saskabush
Sep 4, 2015 06:49 PM
