Check Engine
Old Apr 29, 2010 | 11:23 AM
syrousd's Avatar
My Ride: 2008 550I,Space Grey,Hud,Cold Weather,M - Sport, matched GP Thunder headlights and Fogs,,Smoked Badges, Night Vision, Heated Seats,Rear Sunshades, Aux Audio, SAT, NAV, Black Grills, Sprint Booster, Dinan Cold Air, Stage 2 Dinan Software.....More to come soon
ok...the car is 545i with 72k on it,check engine came on and stays on and also a message "emissions exceeded limits" pop on on the nav screen. Im thinking its an faulty O2 sensor but what do you guys think?
S.
Old Apr 29, 2010 | 11:28 AM
1600's Avatar
My Ride: 2010 M5 alpine white, black full leather, etc.
sounds about right, but you need the dealer to do the work.
Old Apr 29, 2010 | 12:16 PM
bars_sun's Avatar
My Ride: 2004 BMW 545i Titanium Silver
I would not assume right away its an O2 sensor. Was message on iDrive like you typed it or was it "Increased Emissions"?
Old Apr 29, 2010 | 05:05 PM
05545i's Avatar
My Ride: 2005 545i Sport 6MT
Thermostat. I'd bet 50 bucks.
Old Apr 29, 2010 | 05:49 PM
turboawd's Avatar
My Ride: 2006 BMW 550i
check the rubber crankcase valve on the top of the cylinder heads maybe
Old Apr 29, 2010 | 05:57 PM
luigi524td's Avatar
Emissions related parts are covered beyond the 4 yr / 50K miles. Check your warranty for parts and labor that are covered.
Old Apr 29, 2010 | 06:24 PM
Phil75070's Avatar
My Ride: See signature
Had the light come on in mine. Took it to my independent and he couldn't find anything wrong. He reset it and it has not reoccurred.
Old Apr 29, 2010 | 06:40 PM
Dmitry545's Avatar
Same car as mine: the previous two times this happened to me it was faulty thermostat.
Old Apr 30, 2010 | 03:25 AM
bars_sun's Avatar
I'd suggest to start replacing in the following order - thermostat, crankcase vent valves, temperature sensor at radiator outlet, temperature sensor at water pump. Replace one by one and reset CEL each time and wait if you get CEL again. It might be weeks, but might be month before you get another one, so just take it slow and don't replace all in one shot. Just a warning, that it might trigger chain effect on other parts. In my case engine was running cold and after all the replacements engine temperature went back to normal, but triggered weak parts failures in the cooling system - expansion tank cracked and plastic pipe (vent pipe running on top of the radiator) snapped.
gergnang
Feb 2, 2021 07:29 AM
YannickVT
May 7, 2015 11:45 PM
Stranger12
Apr 5, 2015 10:42 AM
laz1left
Mar 11, 2015 11:15 AM
E60Nut
Apr 16, 2004 03:33 PM
