Changing belts cost me $3,300
My Ride: 2015 535D M Sport
The shop that did the initial work should have worked out some sort of deal with you. Parts only, at cost would have been reasonable. The second failure obviously was not a conincidence. You might want to consider taking them to small claims court.
My Ride: 530I Silver gray with gray leather with Premium Package, Logic 7 Premium sound system with Ipod interface, xenon adaptive headlights, Active steering, Power retractable rear sunshade, Comfort seats, Cold weather package and M5 OEM 166 wheels, Sprintbooster. Ceramic Tint all around, Bilstein Sports shocks with Eibach springs, Brake performance Rotors and Axxis ceramic pads.
What a coincidence, my 525 with 120K needs a belt tensioner cause it makes noise. I will have it done by a good friend of mine who has worked on all of my cars and no problems. But here is the deal:
BMW Service tells me that i need to replace the entire belt tensioning system to a hydraulic type because i guess they dont make the mechanical anymore??? And the whole thing costs like $700 bucks.
I found a replacement belt tensioner for $60(max) on ebay. I am not sure if thats an aftermarket or not. I always like to use OEM parts but in this case i think i might get a belt direct from BMW and a tensioner from other source.
Does anyone know anything about this hydraulic system that i was offered? I should be okay replacing the one i have now with a new non-hydraulic right? ...say with this one? EBAY
netjazz, sorry to hear a belt can go crazy and cost all that damage--glad you got off safely. Probably hard to tell anything in that mess, did it look like the belt tensioner failed? Or the belt came loose over short time because it wasn't tighten properly?
I just had the *drive belts replaced a few days ago, but you got me wondering now. There is a DIY but decided to have the dealer tackle it. They replaced two ribbed v-belts, but I don't think the "belt tensioner" was replaced. I have almost same mileage, approaching 145,000 miles. Maybe I should give the service advisor a call?
I had the $3,300 job done by a reputable BMW dealer in New Jersey, 5 miles away from where I broke down. They say on the paperwork and I quote "143072 belt tensioner failed belts broke damaging power steering and trans cooler lines.r&i front subframe, replaced power steering lines front pump to rack and trans cooler lines, replace belt tensioner and pulley and replaced belts and thermostat.
My advise to you with 145,000 miles on the car is DEFINITLY replace the tensioner at once. The new belts you put on could be enough of a change to stress the tensioner. Talking a lot of money. Don't take the chance.
My Ride: 06 530XI Sapphire Black, Black Int. 6sp, Cold, Prem
I'm sure there are dozens of horror stories out there based around someone's experience at the dealer.
My cars go to a small BMW center, they touch it and never the dealer.
shervinj
04-23-2015 05:42 AM
