Change from run-flat tyres
Old Apr 10, 2009 | 08:03 AM
timo's Avatar
My Ride: 2006 520d SE 163bhp, Saloon, Grey, no factory fit extras, no mods. (yet...).
Does anyone have any advice on changing from runflat to standard tyres ?
Thanks,
Tim
Old Apr 10, 2009 | 08:14 AM
Ricracing's Avatar
Thanks,
Tim
Do it at once!
Much better comfort and more silent drive.
Old Apr 10, 2009 | 09:39 AM
vlad_b's Avatar
My Ride: 2005 BMW 545i Sport Package, Jet Black M166 OEM Wheels M5 Style Body kit RPI Scoop BMC Air Filter Valentine One Radar Detector 35% tint all around
definately worth to do that. much better ride and less noise
Old Apr 10, 2009 | 10:01 AM
CWS530's Avatar
Originally Posted by Ricracing' post='843035' date='Apr 10 2009, 11:14 AM
Do it at once!
+1 It's night and day.
Old Apr 10, 2009 | 10:48 AM
gwf545's Avatar
My Ride: 2015 535D M Sport
Ditch the runflats as soon as possible. I've had both the Dunlops and Bridgestone's on my car and when I switched to Michelin PS2's it was a huge improvement in ride and noise. Handling was somewhat different, but not necessarily worse. The runflats sidewalls are so stiff, it makes the car somewhat twicthy (fast turn-in). The slightly softer PS2's were noticeably less twitchy, and some drivers would consider that a negative, but it doesn't bother me at all.
Old Apr 10, 2009 | 12:21 PM
530xda's Avatar
and better fuel economy, well some at least
Old Apr 10, 2009 | 05:18 PM
faarcanal's Avatar
My Ride: Current - MY2008 530i comfort access,active steering, HUD, prof nav/TV, bluetootth etc ..... Old - 2006 530i comfort access, active steering, HUD, NAV/TV, Bluetooth
Don't change!!!! Get away from the Dunflops though. I now have contis and the problems I thought were the runflats were in fact the Dunflops.
If you like driving keep the run flats,
BUT, if you are a yank and think the suspension should float over bumps, then maybe the non run flats are for you.
BTW - on Monday last I drove the soon to be released 750i and played with the suspension settings. The result? With 21inch run flats the suspension modes varied from float over bumps to fairly hard stuff compliant cornering. Maybe this technology will trickle down to the f10.
Old Apr 11, 2009 | 01:47 PM
ObD's Avatar
ObD
My Ride: 2008 535i 6MT
Non runflats are far superior to runflats. You'll save at least 5 lb/tire. Numbflats have no road feel. Runflats = FAIL.
Old Apr 11, 2009 | 02:33 PM
timo's Avatar
I had Goodyear runflats on the car from new then changed to Bridgestone potenza run flsts.
On the SE spec the ride seems fine with runflats, however I have noticed a significant increase in road noise from about 50% worn - sounds like a wheel bearing has gone.
i was wondering if I changed to non-runflat if the tyres would be quieter when more than 50% worn.
Thanks,
Tim
Old Apr 11, 2009 | 03:22 PM
mhs525's Avatar
Hate run flats, at least the ones that came on my car. Car tramlined horribly, felt unsafe on highways. The car is fantastic with Michelin Pilots and my lighter BBS wheels also help. I am probably down 7-9 lbs a wheel between the wheels and tires. Completely changed the car.
