Central Locking Issue or Coding issue HELP!
My Ride: E60
![Red face](https://5series.net/forums/images/icons/icon11.gif)
Hi everyone,
My name is Tony and I need the community help for something that I have not seen before.
The car is E60 2008 BMW 528i N52 engine with 105k miles.
The issue:
Everything seems to work perfect but the central locking is acting up. Everything works as it should ( or as far as I know ) but when the drivers door is open and then closed everything locks simultaneously. Like right away. It does not make a any difference if key is in or out the car. In the ignition or out, even when the car is running it locks. I know for sure that the key is not original BMW key. I mean it was made from a locksmith. Is it a coding of the CAS issue or something mechanical like a door lock.
I scan the car with ISTA and all is fine green modules all the way.
Thanks to all in advance and any help would be greatly appreciated.
P.S. New to forums so if I have posted in the wrong section I am sorry guys.
The issue:
My Ride: 05 BMW 525
Engine: M54B25
Hi everyone,
The issue:
The issue:
My Ride: E60
Hello there and thanks for taking the time to share my pain ![Smile](https://5series.net/forums/images/smilies/imported/smile.gif)
I did that and it unfortunately everything was coded ok, so after 5 days of reading/learning coding and comparing the code with other E60's on the net I decided to go with new Door Lock Actuator and that fix it for me. Hopefully this can help someone else as I have not read or seen a malfunction like that.
Thanks again!
Thanks again!
