CD Tags
Originally Posted by Alec' post='230667' date='Jan 27 2006, 11:27 PM
[quote name='kigerka' post='230619' date='Jan 27 2006, 01:25 PM']
iTunes does not support CD Text. Try Nero Rom from www.ahead.de
[/quote]
What about Roxio Toast?
[/quote]
Yes I thinnk it does but to be sure you may want to go to the website and double check.
For any Mac users out there, Roxio Toast takes care of adding CD-Text. Also, If you play the disc through the NAV's DVD player (select DVD as the source) then CD-Text IS supported. Hopefully a future iTunes update will take care of the CD-Text issue as it's a major oversight in the curent releases.
Ok I still cant get it to work... What Hardware and what software version is needed on the car to support CD-Text?
I'm running v16.2 and have Business Radio Not Professional Radio that comes with Navigation.
Is Prof Radio needed for CD-Text??
Edit: well I tried two store bought CDs that contains CD Text and nothing comes up so apparently No CD Text for me either... :thumbsdown:
Ok. Not sure I'm getting this. Are you saying that if I burn a DVD audio disc using Toast and then put it in the DVD slot I will get approx 4.7Gb of music? Found the CD text tick box in toast and Ic Holmfirth is right, you have to select DOA option.
I would not think that you would need Pro radio but I guess it may be possible. I just updated my cars software to 22 or 24 and before I had version 12 and it supported CD text.
My Ride: F02 LCI Individual
Model Year: 2013
Originally Posted by kigerka' post='230853' date='Jan 28 2006, 08:56 AM
However, if you are burning an audio cd it currently does not support CD text.
Model Year: 2013
Originally Posted by kigerka' post='231296' date='Jan 29 2006, 09:41 AM
iTunes now supports CD Text?
You're right.
I thought it does, but it doesn't.
I thought I have burned a CD with text using iTunes, but it wasn't iTunes.
![W00t](https://5series.net/forums/images/smilies/imported/w00t.gif)
Anyways, you're right...
No answer?
