Car stalled twice on the way home :(
Old Apr 5, 2010 | 04:38 PM
1diver1's Avatar
My Ride: 2005 545i - Black on Black, Maple Anthracite. Cold, Premium, Sport, Nav, Heads Up Display, Logic 7, Power Rear Sunshade.
I've been getting the increased emissions warning off and on and then this weekend it stalled when backing up. On the way to work today; once the car was warmed up it started to die when I pressed on the gas and then engaged, like it was starved for fuel. On the way home it did it again but worse. Twice it stalled, a couple of times rev'd up then engaged and all the while the tac was all over the board. I have an appointment with the dealer on Wed. morning but I'm out of warranty. God I hope it's not anything big. Thoughts?
Old Apr 5, 2010 | 04:42 PM
Ceenit's Avatar
My Ride: 525
Could be any number of things from as simple as bad gas, to o2 sensor or cat. How many miles are on the car? Did you pull any OBD2 codes to get specific error messages?
I'm sure the dealer will figure it out quickly. If it got to the point of stalling the car, defintily not something you would want to put off any longer.
Old Apr 5, 2010 | 04:53 PM
1diver1's Avatar
Thanks for the reply. Only use premium, 68K on the car. I'll look into searching the codes.
Old Apr 7, 2010 | 06:17 AM
05545i's Avatar
My Ride: 2005 545i Sport 6MT
Pressure regulating valves. One on each valve cover. Very easy to change. Will run you about 30$ each at the dealer.
Old Apr 7, 2010 | 07:38 AM
bmwgroup's Avatar
Happened to me once, it could just be faulty fuel pump with the high pressure failing. Good luck and keep us updated
Old Apr 7, 2010 | 08:26 AM
Howitzer's Avatar
Or filthy fuel injectors. Could be a number of things.
Awest91
Sep 17, 2022 11:05 PM
Kasmo
May 7, 2019 03:30 AM
BMW565
Nov 6, 2017 06:03 PM
i6YouNot
May 19, 2015 02:40 PM
E60_530D
Dec 14, 2003 03:26 AM
