Car Jerking??
Old 07-15-2008, 04:31 AM
khooger's Avatar
Originally Posted by xxrap985xx' post='624065' date='Jul 14 2008, 11:10 PM
no i didnt.. i still have the warranty on the car, should i just get the dealer to check and would it be cover under warranty?
That would be the best bet.
Old 08-08-2008, 09:08 AM
jleev22's Avatar
What did the dealer end up doing? My car is doing the same thing 04 530i with 74k miles on it. I had the plugs changed before I bought the car, but we are still having the studder.
Old 08-08-2008, 09:12 AM
Cwest's Avatar
Give your transmission and rest and see how that goes, here is the link on the fourm about jerky trans http://forums.e60.net/index.php?showtopic=...et+transmission Hope this helps. GL
If that doesnt help try this one-->http://forums.e60.net/index.php?show...t+transmission
Old 08-16-2008, 08:47 PM
phocker's Avatar
i have a similar situation with the jerking. but this is when im at a low speed. for example when i slow down to pull into my driveway and i slowly accelerate and then it jerks. is this normal? should i expect this from a v8?
Old 08-17-2008, 12:56 AM
NPe
NPe's Avatar
My Ride: M6 E63 Sapphire black Z3 Coupe R4Turbo Hellrot, semi race. (670bhp) Z3 Coupe V8Turbo design work ongoing, full race. Sold: 545i Titanium Silver
I?ll say plugs.
Another issue that could occur, but usually on cars with many miles on them, and give the same jerking behaviour.
Contaminated injectors.
At low load the injectors have very short opening time. If the injector is the slightest contaminated it will not give a appropriate fuel mist and spray pattern, instead it will have small fuel drips in it. Or the spray pattern is missaligned.
Fuel/air mixture will not be sufficent and missfiring or bad combustion will occur. Not like it will caugh and limp, but just as much noticable as jerking.
In that case, try cleaning additives in the gas. If that not work you?ll have to use ultrasonic cleaning.
Old 08-17-2008, 01:02 AM
OliverB's Avatar
Yes, plugs, or/and maybe bad quality fuel
Old 08-17-2008, 06:43 AM
elk42's Avatar
same thing here. calling monday for appt. i also want to see if my 05 needs the recall fix.
Old 08-20-2008, 09:32 AM
benc008's Avatar
What is the recall fix? If you are referring to a software update, I'm not sure if it will fix the problem. I have a relative who's worked for BMW Service for decades told me that this is a common problem for the 5 series. There should be a fix later on this year.
Old 08-20-2008, 09:41 AM
Ricracing's Avatar
Originally Posted by xxrap985xx' post='624053' date='Jul 15 2008, 05:59 AM
My car is jerking very lightly when i go from 40-45mph and only at that speed.. does anyone know what could be causing that???
Your tires are not in balance. The syndrome is at it's worst at 90 km/h.
20 inch what ever wheels and tires - very typical.
The warranty has nothing to do with the after market wheels/tires, sorry.
Awest91
09-17-2022 11:05 PM
BLACK_PRINCE54915
05-08-2019 02:45 AM
Kasmo
05-07-2019 03:30 AM
stilldre54
04-03-2015 02:59 PM
james69z28
03-23-2015 06:45 PM
Quick Reply: Car Jerking??
