Can I use an iOS diagnostic tool to code modules?
Old Sep 22, 2022 | 07:22 AM
Dark Vader's Avatar
My Ride: 2010 E60 535i Sportline, 20" wheels, soon-to-be custom stereo
Default Can I use an iOS diagnostic tool to code modules?
Can I use something like Carly or BimmerCode (Expert mode) to code a new module I’ve replaced in my new to me 2010 E60 or do I need an actual computer/cable and the software for that?
I added a ‘new’ MULF2 to my car because my old one was completely corroded… it has the matching part numbers so it worked as soon as I plugged it in (BT/AUX came back) but my phone (iPhone 13 Pro max) isn’t recognized by the USB… people have told me that the mismatch is because my MULF2 needs further coding… is that true? If so, what do I need to do?
thanks
Old Sep 22, 2022 | 11:28 AM
seanjordan20's Avatar
Engine: 3.0 B58; 3.0 M54
I let you know on your other post the parameters of why you would need to code the new MULF 2. Every car is not equipped with the same options so when you buy a used module things may likely need coding prior to using it.
I personally do not use apps to code anything on these cars but if you are going to use anything it would be BIMMERGEEKS Protool. Any other app you risk damage.
Hope this helps in what you were asking. I believe I'm the only coder on here so you may not get any other responses. You need to invest in a 75a car charger, laptop, ISTA and BMW tools software if you think you are going to become a DIYer. It will save you a headache in the long run. Yes it's expensive up front but it will save you a lot of money down the road if you plan on keeping a 10+ year old BMW.
I just gave you the best advise you will get on any forum. Do with it as you will.
Old Sep 22, 2022 | 07:11 PM
donpb's Avatar
My Ride: '06 530i N52
@Dark Vader Or you can pay someone. I needed my modules updated, and I could have DIY'd it, but the price of buying all of the equipment and configuring it all and learning curve, I just paid the guy and was done.
Old Sep 22, 2022 | 10:22 PM
This too. It's beneficial to me because I have multiple cars and work on BMWs so I use it all the time.
Old Sep 23, 2022 | 01:15 AM
Dark Vader's Avatar
I have ISTA and a cable, I’m just not confident I set it up properly… where are you located? I’m in LA
Old Sep 23, 2022 | 01:31 AM
I'm in MD. You don't need ISTA to do what you're trying to do. You need to install Mikes easy BMW tools (I think that's what it's called) and factory code the module with NCSEXPERT and that's it.
Old Sep 24, 2022 | 10:38 PM
Dark Vader's Avatar
thanks… I haven’t found a reliable/safe source to downloaded Mikes tools, do you have a suggestion?
Old Oct 30, 2022 | 12:45 AM
gt67's Avatar
My Ride: 530d e61 2009 pack luxe
slt
alors attention les gars codage avec stabilisateur de tension a 14v et avec un cable icom car sinon vous prennez des risque de planter un module
paneuro
Aug 10, 2021 01:08 PM
uas66
Jan 12, 2015 03:49 PM
Giowizzy
Aug 31, 2012 01:02 PM
jasonkey
Aug 29, 2012 03:16 PM
sd_dracula
Jun 1, 2011 09:16 AM
