Calling Garry on Monday to order my new 166s
Finally, after nearly a year of looking, I am ordering the 166s From Garry of Newport on Monday. I am unsure what tires to put on. I have been looking at the Michelin Pilot Sport A/S and the Bridgestone RE960 Pole Position A/S. What do you recommend? Those that switched out, did you do the TPMs as well?
I am interested in the ET17 that was talked about in the MikeBuzzsaw group buy last month, if anyone has info on those sizes.
By the way I have the 2007 550i Sport Package.
Thanks,
Brian
Thanks,
Brian
Is there a reason you want All-Season tires only? Why not go for Summer performance tires and use your old rims with winter rubber? If so, I'd go for the Michelin Pilot Sports PS2's if you can afford them. I had a set of Bridgestone RE050A Pole Position's and didn't care for the road noise or the cupping they developed. There are certainly cheaper options, so read up on the ratings on TireRack.com. 245/35/19 F, 275/30/19 R.
http://www.realoem.com/bmw/showparts.do?mo...hg=36&fg=15
ET12 Front: Part #36117834625
ET17 Rear: Part #36112283160
Originally Posted by silver2000stang' post='597446' date='Jun 6 2008, 10:24 PM
With the M6 offsets, would I be able to do a 285 on the rear?
What are you planning up front for tire width? You will have to run 245's.
Thanks,
Brian
Thanks,
Brian
Good call on the wheels and Garry !!!!!
PS I did the M5 166's , you can see the look in my album .Good Luck
Originally Posted by geneatals' post='597456' date='Jun 6 2008, 10:37 PM
But u're not biased
biased ? I'm hetro !!
BTT: silver2000stang, nice choice on wheels, GL with your purchase....
not sure if you saw this thread regarding tire size:
http://forums.e60.net/index.php?showtopic=...mp;#entry575726
Originally Posted by geneatals' post='597467' date='Jun 6 2008, 10:46 PM
hetro, better than metro
