A/C Pro Needed - 06 530i E60 AC Blowing Warm Air & misery. i have scan tools & cider
Old 02-26-2018 | 12:07 PM
  #51
Ohainey's Avatar
My Ride: 2006 E60 530i,
Oh ok. That's when things suck for the owner because you have no idea what happened leading up to it. You're good I think the route you are going is the most cost efficient. Like yourself I do not believe in through parts at a car. I will trouble shoot something until I find out what is the actual fix. I worked on my ac for 4 months before I found out what is was. Then again it was winter so I took my time with it. I'm sure you will find your issue if you keep at it today or tomorrow. Thanks for keeping at it and keeping us posted.
thanks Sean, its the first I have posted looking for help, I grew up in Ireland and I was thought as a young mechanic that real men don't use manuals, but then again real men don't drive bmw's in Ireland haha they drive tractors and beat up old issue troopers with calves and donkeys in the back
This fucker will be blowing cold air by weeks end or ill strap my cold-hearted EX in the back seat holding a big block of dry ice (rumor has it, it will extend the Dry Ice indefinitely)
Old 02-26-2018 | 12:58 PM
  #52
Ohainey's Avatar
I started adding Freon. 28.5 ounces is the required refill. Im about 18ounces in six fan ian kicking in but it’s not really taking anymore Freon and no cold air.
The gagues are pretty much equal.
After leaving engine running for 10 mins
Old 02-26-2018 | 01:20 PM
  #53
Ohainey's Avatar
I read someplace that faulty low ambient temp sensor can stop the compressor from working. Temps are reading correctly with scan tool live data
I’m running quick trouble code scan right now.
So are we all agreed that is the compressor at this stage ? Or is there anything else that needs to be checked ?
Old 02-27-2018 | 05:14 AM
  #54
seanjordan20's Avatar
My Ride: 05 530i M54
Model Year: 05 530i
Engine: 3.0 M54
I thought about something last night you said the coolant ran out the engine. Did you bleed the system after filling it back up
Old 02-27-2018 | 05:37 AM
  #55
Ohainey's Avatar
I did bleed it Sean. Accelerator for 10 seconds and all that jazz.
Old 02-27-2018 | 05:41 AM
  #56
Ohainey's Avatar
I'm running a few test tests to see if I can get signals at compressor and sensors.
I have a blue 528i that needs tranny work. So I’m just going to start swapping compressor and other parts if need today then have my 530i compressor reconditioned.
Old 02-27-2018 | 05:51 AM
  #57
FormerE30Owner's Avatar
My Ride: 2005 545i, premium package, 6sp manual, cold package, navigation package.
Model Year: 2005
Engine: N62
Originally Posted by KyleB
RealOEM.com - Online BMW Parts Catalog
That's the diagram using my VIN. It looks like a clutch, but in reality it's just a big pulley. All E60s use a variable vane compressor.
Yet, if one continues to drill down the parts catalogue, the part is referred to as AC compressor, magnetic clutch. The magnetic clutch, although part of the compressor is not used or wired up, which explains Sean and your differences. BTW, I bet you could activate/deactivate the clutch so that the compressor would work as the "old" one did.
Would have to place the variable displacement selenoid in max position, though.
Old 02-27-2018 | 06:01 AM
  #58
Ohainey's Avatar
If the compressor is fucked internally could that account for the lost in pressure when pulling a vacuum ?
Old 02-27-2018 | 02:40 PM
  #59
Model Year: 2005
Engine: N62
It depends on what might be "fucked". The variable swash buckle mechanism can be worn and defective, but that won't cause a leak. If there is a seal leak in the compressor (at the pistons) and the variable feature still works then the leak would be internal and the compressor would lose efficiency, but would still work. If you have filled the system and tried it without detecting a leak using a dye and you still don't get cold, then I guess your compressor is defective. BTW, although messier and not exactly environmentally good practice, a pressure leak test is more likely to show a leak than a vacuum test. The pressures are higher when charging freon than a vacuum can pull. You meters show that. 110psi on pressure side versus a max of 30psi on vacuum side.
Old 02-27-2018 | 03:50 PM
  #60
Ohainey's Avatar
So I put the gauges on the blue 528i and they are reading 100 psi low and high when car is not running. Is that normal ?
I'm pretty sure the a/c was working on this car before I ripped tranny.
I have the valve body out of the transmission. This might be a ridiculous question. But can I start the car briefly with the valve body removed and the oil sump cover on the tranny to test the a/c or will it do damage ?
These are for asking a question I'm fairly sure I know the answer too. But I always have that voice in the back of my head says fuck it sure what's the worst could happen !! Haha
