A/C elastic belt how to replace ?
My Ride: BMW
Engine: M57D30TU TOP
Hello.
How to replace A/C compressor elastic belt without tensioner, or it is better to buy a special tool? In here > BMW TIS. Просмотр документа
I have BMW 535d e60.
Thank you
Thank you
My Ride: 05 530i M54
Model Year: 05 530i
Engine: 3.0 M54
You have two options.
1. Buy a belt remover tool and turn crank with a socket wrench
2. Have someone help and as you are turning the crank slip the belt off.
Both way are easy but the second save you $$
My Ride: 545i sport
Most make a tool...do a couple of searches and you will see examples of homemade tools. I made a tool from hose clamps purchased from Harbor Freight. Worked ok, but still a PITA. Ultimately, I elected to install a tensioner pulley. Now it is a piece of cake to remove/install the belt.
My Ride: BMW
year 2004
There's a problem, the bolt on the pulley does not rotate, but the small four screws
look this> BMW TIS. Просмотр документа last picture
My Ride: BMW
socale39
09-05-2023 08:30 AM
Thomas the Swede
09-13-2003 12:22 PM
