Sponsored by:
Sponsored by:
i-drive screen is white, bad screen?
Old 07-01-2018, 08:23 PM
motopokep's Avatar
My Ride: 530i
Default i-drive screen is white, bad screen?
04' 530i, I had INPA connected and started the engine, and idrive screen went white with some thin flickering lines toward the bottom. everything works, CD, radio, door chime, but the screen won't reset after the 3-button reset, after disconnecting the battery, after driving around, after having car locked overnight. I'm thinking it has to do with me starting the engine while in INPA cuz that's exactly when it happened. I wasn't in any screen or communication settings though, I was in functional jobs. I'm betting the CCC is fine and I need to replace the screen, any thoughts?
Old 07-03-2018, 04:42 PM
motopokep's Avatar
My Ride: 530i
solved! removed the screen via the 2 torx screws, disconnected the 2 wires, turned on ignition, turned off ignition, reconnected the 2 wires, turned on ignition, screen works flawlessly. sometimes disconnecting and reconnecting something fixes it.
Old 07-10-2018, 03:55 PM
LessIsMore's Avatar
My Ride: 2009 535i Sport
Model Year: 2009
Engine: N54
ha, can't believe that worked - nice job.
Never had the screen do that - however I've already replaced my idrive/CIC unit once, and now the new/used one is going bad.
Ricracing
Lounge
02-28-2012 05:25 PM
Presley348
09-06-2010 08:24 AM
OverSoft
08-31-2009 08:04 PM
diplo
03-02-2009 03:20 PM
saurabh
03-17-2005 09:19 AM
Quick Reply: i-drive screen is white, bad screen?
