breaking traction
My Ride: Numero Uno in Richmond Va 04 530 6 speed, jet black, black dakota leather, xenons, red rear reflectors, 545 front grill, cold weather package, premium package, 19 inch BBS rxII/michelins
Guys i tend to drive pretty agressively but safe, but i have noticed that i am not able to even slightly chirp the tires of my e60 with or without the traction control and dsc off what gives . Could it be the clutch delay valve or does this car just not have enough power? I am not into the boy racer burn outs or anything like that but some type of second gear antics would surfice, at this rate i will never wear out my ps sports. Hey as much as they cost though that might be a good thing NAWWW i want a little smoke from time to time how bout you 530 owners
My Ride: Now Driving a Freakin' Prius!
Was...
2004 545i | SMG | White/Black | Sport | NAV | Logic 7 | PDC | Fold-down Seats | Adaptive Headlights | Cold Weather Pkg | Clear-again Bra | Mud Flaps | Bluetooth | Coat Hangar | Aux Input | All Weather Mats | 18"X8.5" BBS RK w/ Michelin Pilot Alpin's (winter) | New steering rack @ 1.2K & 17K miles| Software V.19.1 | B&B Exhaust (vrrrroooooommm!) <---Click.
What's your set up? It appears that you are running a 530i with a 6-speed manual???
My Ride: Numero Uno in Richmond Va 04 530 6 speed, jet black, black dakota leather, xenons, red rear reflectors, 545 front grill, cold weather package, premium package, staggered 19 inch BBS rxII/michelins, H&R coilovers and intergrated, R1 concept drilled an
Engine: 530i
Rudy first of all i am sorry, it appears that i have to accounts with this forum one under buddy member #272 and buddiec member 447 i would prefer to use the first one as i have a wopping 174 post versus 24 for the other account since i dont have a 545 my low member number offers a symblance of superiority
by the way realtyman my set up is in my signiture now
![Innocent](https://5series.net/forums/images/smilies/imported/innocent.gif)
Originally Posted by realtyman' date='Sep 25 2005, 09:11 PM
What's your set up?? It appears that you are running a 530i with a 6-speed manual???
[snapback]174923[/snapback]
Was...
Thanks for updating your sig.
Now that I know what you have and not having a 530 I can't help.
Hopefully some of the 530 6-speed (non-SMG) can help you out.
Try to turn all systems off (even the car) kiddin.
Anyway turn dsc off, select 1st, build up the revvs almost to the redline and then quickly dump the clutch and floor the throttle and away u go. That should be more than enough for some wheel spin and myabe even for some smoke!
Was...
That'll light the right rear up fo sure (at least until the clutch explodes
![Wacko](https://5series.net/forums/images/smilies/imported/wacko.gif)
Engine: 530i
a chirp or even an actual burn out is no problem out of first gear with all system turned off, its the second and third gear snatches that i dont understand why it wont do it. I may be the clutch delay valve or even the longer throws of the gear spaceing. This is not a really big deal but even in my fiat 131 super brava i could snatch second gear and it probably had 115 hp at the most.
My Ride: 2003 X5 3.0----->gone
2004 Porsche Cayenne S : Gemballa front and back bodykit, fabspeed bypass pipes, Gemballa exhaust pipes, full option, 20" factory sport design rims------>gone
2005 545i 6-spd manual---->de-badged, CDV removal, Autosolutions short shift kit, resonator removal, premium package, PDC, xenon, almost full options, hardwire V1 install ....looking for mods...
2007 550i 6-spd----> Premium package, sport package, Logic7, heated everything, Rogue Engineering SSK, CDV removal, hardwire V1 install, aFe cold air intake, Custom Magnaflow exhaust....
maybe the car does not have enouhg torque to begin with?
My Ride: 09 E90 M3
You'll need to be real brutal and quick on the 1-2 shift to get a chirp...I've only had it happen 2 of 3 times on my SMG in Accelaration assist mode. And this is on slippery 225 width SNOW tires
![Noexpression](https://5series.net/forums/images/smilies/imported/noexpression.gif)
Originally Posted by buddy' date='Sep 26 2005, 04:52 PM
a chirp or even an actual burn out is no problem out of first gear with all system turned off, its the second and third gear snatches that i dont understand why it wont do it.? I may be the clutch delay valve or even the longer throws of the gear spaceing.? This is not a really big deal but even in my fiat 131 super brava i could snatch second gear and it probably had 115 hp at the most.
[snapback]175412[/snapback]
Well keep in mind... your fiat is a Front wheel drive? so when you are accelerating all the weight goes to the rear of the car which makes the front a lot lighter and hence no weight up there... Much easier to spin the wheels.
On the other hand... the E60 is a rear wheel drive with those nice wide 19" wheels (I assume they are wide since they are 19"s) and grippy Michilins its harder to chirp them. The weight during acceleration is all thrown to the rear all pushing down on those 19"s... makes it stick to the ground more.
