Brand of paint used at the factory
Does anyone know what manufacturer BMW uses for exterior automotive paint at the Munich factory? Is it BASF, DuPont, PPG, Sikkens (by Akzo Nobel)? I need to match the factory paint. Thus far the prime variant of PPG and Sikkens did not doe the trick. Thanks for any help.
My Ride: 545i Individual 2005
Model Year: 2005
The cars are painted usually in electrostatic field, so the paint used is very different from the spray type one. The only things that you can match is maybe the supplier of the paint ( maybe they have also some spray type paints, and the color pigments are the same).
Thanks for chiming in!
I thought that only primers were applied in the electrostatic field and the paint and clear were simply sprayed on under clean-room environment. There is an article online that summarizes a tour through BMW factory. The author of this article claims that BMW uses waterborne paints. The only supplier of waterborne paints I know of is BASF with their Glasuri Waterborne Paint line.
Does anyone else know anything about this?
My Ride: 07 525i
Thanks ukamath!
I plan to stop by a local auto paint supply place on Saturday to check out their BASF Glasurit products. This place also has color samples for every color code. Lets see what I find.
srogers535x
08-05-2015 08:48 AM
Bank$hot530
07-12-2015 04:36 PM
