braking problem
Old Oct 20, 2005 | 07:52 AM
browellm's Avatar
Unbelieveable dealer attitude
Old Oct 20, 2005 | 08:04 AM
AC_S5's Avatar
They should go and do a test drive with you regardless, they shouldn't brush you off like that and you shouldn't walk away either. Which country are you from?
I think the problem is brake related since you say your brake squakes, if one brake is stopping faster than the other than it could throw your car in a different direction. If it is a tire problem than the car should act like that even when you are not braking.
Old Oct 20, 2005 | 02:01 PM
Iceman's Avatar
My Ride: F02 LCI Individual
Model Year: 2013
Originally Posted by abs' date='Oct 20 2005, 04:10 PM
THANKS GUYS IM GONNA GO BACK TO THE DEALER AND CREATE A SCENE IF THE MATTER IS NOT LOOKED AT
[snapback]186535[/snapback]
You better do so.
There is defiantely something wrong and THEY HAVE TO LOOK AT IT!
Old Oct 20, 2005 | 03:11 PM
znod's Avatar
Take your car back after making sure your tires are inflated to BMW's recommendations. If the front, on the side the incident occurred, is quite low in comparion to the front on the other side, then go back to the spot where the problem occurred and (carefully) see if it still occurs after filling all the tires as suggested. I would go back to the dealer and insist they they check things our regardless. There is no point in making a scene unless you want to be disrespectful to yourself. Just point out obvious things--they are obligated to check; you will sue them if you have a wreck; you will report them to BMW; you will report them to the where-ever-you-are version of the BBB; you will ..., ..., ..., etc.
Awest91
Sep 17, 2022 11:05 PM
UltimatePeter
DIY: Do It Yourself
Sep 28, 2015 09:12 AM
2004_545i
Apr 8, 2015 04:01 AM
Sakru
Mar 26, 2015 09:26 AM
lc holmfirth
Mar 22, 2015 10:28 AM
