Brakes squeal at 14000 miles
Old 10-07-2004 | 02:10 PM
my530i's Avatar
Does anyone have your brake squeals? It squeals when I press the brake a little hard. Is it normal? I've been told by service advisor that it's the brake sensor causing the squeal.
Thanks.
Old 10-07-2004 | 02:44 PM
530E60NL's Avatar
If that would be the case you should get a warning in your I-Drive that your brakepads are worn out.. My previous 330 had 50.000 kms on the odo with the first brakepads and I never had a squeel..
Old 10-07-2004 | 03:38 PM
Aaron's Avatar
My Ride: On Order: 2006 525i Alpine White Auburn Interior Premium Pkg Sport Pkg Cold Weather Pkg Xenons Sunshades Sat Radio Navigation
The high pitched squeal could be the mechanical indicator of the breakpads. Many breakpads use this technology. I was unaware of the sensor monitoring the breakpads electronically, but nevertheless, if it is the sensor, that just means it is time for BMW to change then under the Maintenance agreement. No money from you, just a little time.
pcy
09-12-2021 07:55 PM
dsummersm3
11-14-2019 08:50 AM
kongse
07-17-2015 04:29 PM
Jorgemorascv
05-17-2015 08:06 AM
TexaZ3
05-06-2015 10:54 AM
