Brakes reset via I drive
Old 05-26-2009, 08:24 PM
  #21
5satku's Avatar
Originally Posted by andy545' post='563090' date='Apr 17 2008, 11:38 AM
not via the idrive, from a previous post on the forum:
Firstly with the ignition switched on, set the odometer trip meter back to zero by pushing it once. Then switch the ignition back off again. (I found this step was critical, otherwise I couldn't get to the "Service" menu).
Now you are ready to go through the reset steps as follows:
1. Switch the ignition on (so that the battery, Oil and Parking brake lights are displayed) and the key is ready to start the engine - but don't actually start the car.
2. Press the odometer reset button for between 5 and 10 seconds until a yellow triangle with an exclamation mark in the centre appears in the top window between the clocks (where the outside temperature / time or date normally appears) - this is the "Service" icon.
3. Release the odometer button briefly and press again straight away which brings up a picture of the Brake Fluid symbol (same as the one that the i-drive shows when you look at the Service menu).
4. If you want to reset the Brake Fluid interval for another 2 years then keep holding the odometer button until the word "RESET?" appears at the bottom of the lower window.
5. Release the button briefly and push it in again and hold for about 5 - 10 seconds until the new date appears in the bottom window. You can then switch the ignition off and the new Brake Fluid date will appear in the service menu on the i-drive screen next time you switch on.
6. If you want to reset the Oil, Microfilter or Brake Pad indicators then you will need to follow the same sequence as steps 1 and 2 above, but when you get to step 3 and the brake Fluid icon appears, just release the button and press again and the next service item will appear.
7. You can continue releasing and pressing the button until the required service item icon appears for the one you want to reset. As soon as it does then hold in the button in until the word "RESET?" appears again as in step 4 above. Once the word "RESET?" has appeared, you need to release the button briefly and hold it in again for about 5 - 10 seconds until it is replaced by the new service interval figure (as per step 5 above).
Hints & Tips
Before actually resetting anything, go through steps 1, 2 and 6 above until you are familiar (and sure) what you want to reset. Practice this a few times and note down in what order the icons appear after the initial "Service" icon appears.
If you do happen to hold the button down too long against an item you don't want to reset and the "RESET?" appears, just leave the button alone for 10 seconds or so and it will not let you reset the item. (Alternatively just switch the ignition off and start again).
Sometimes if you have not released and pressed the button again quickly enough, when you hold it down again the German technical writing will appear after about 15 - 20 seconds instead of the Service item icon you were expecting. (If this happens just switch off the ignition and start again).
Once you are sure what item you want to reset and are confident of the sequence, then give it a go. If you do hesitate between releasing and pressing the button at any time, you will have to go back to the beginning and start again as "he who hesitates is lost".
I changed my front pads and also new sensor, BUT when i tried to reset e-drive i fucked up and i resetted rear pads and after that e-drive showed rear pads
-25000km and couldn?t reset that again. After this i nicely resetted front pads. Any ideas ?
Old 07-04-2009, 07:20 AM
  #22
mystarzk's Avatar
This may have been answered before, but instead of resetting to a time or value further away, can we reset to a value that's closer? For example, the oil change is showing 4500 miles, but I'd like the reminder to be at 3000 miles.
Thanks
Old 08-13-2009, 01:54 PM
  #23
skEwb's Avatar
My Ride: 525i
this is awesome thanks for posting this... found it a bit too late after i ordered a $20 reset tool :/
Old 08-22-2009, 11:52 AM
  #24
Bluesky4x4's Avatar
Mine kept saying -15000 miles, after getting the ------. I found this other thread that said to hold the button down one more time, and that worked perfectly.
https://5series.net/forums/index.php?showto...53&hl=15000
Old 11-05-2010, 07:02 AM
  #25
2004BMW545i's Avatar
Originally Posted by stankustov
if it jumps to -9000 than you need computer to reset it, that what i did
I just reset mine and it jumped to -9000. To fix it, you need to do it again, but this time DO NOT release the button when the mileage changes from -9000 to ----.
Keep holding it in until the new mileage shows up (25000 on mine).
Old 02-28-2014, 11:03 AM
  #26
steverino's Avatar
My Ride: 530xi
Engine: 6 cylinder
I just had the front brakes replaced on my 2007 530xi and the mechanic reset the computer to 25,000 miles. I had 55,000 miles on the OEM brakes . What should it reasonably be reset at with the new brakes?
Awest91
09-17-2022 11:05 PM
BMW565
11-06-2017 06:03 PM
TexaZ3
05-06-2015 09:54 AM
lc holmfirth
03-22-2015 10:28 AM
jhalsey
01-25-2004 04:34 PM
Quick Reply: Brakes reset via I drive
