Brake Question
My Ride: 2008 BMW 550i Sport Carbon Metallic / Black
Traded in:
2005 BMW 545i Sport Black/Black
I began to have the dreaded squeaking brakes [metal squeaking/Grind, not little mouse squeaking]... so i took the car into a local BMW dealership. They would not take the car in for service because the computer said the brakes didnt need to be serviced. I told them that there was also some pulsing and that the driver thinks the brakes need service screw what the computer says. So i was able to get them to take the car for a test drive... The "shop Foreman" drove my car and returned telling me that i am too picky and the brakes are perfectly fine. (at this time there were no visual blemishes on the rotor) well 500 miles later the pulsing got worse and now i have a very distinct grove mid-rotor [Driver Front]. I took it back and needless to say the dealership told me i need to have the brakes serviced....OK well, conviently i was now 300mi over my warranty... fts!
So besides the dealership being cheap. what is the purpose of this so called wear sensor? IF it is indicating that my brakes are fine AND grinding the rotor at the same time... any suggestions? PLUS isnt there only one wear sensor, and it happens to be on the Driver Front [Damaged Rotor]? Pictures below...
Should i go ahead and replace the front brakes, even tho the computer says they have 6k miles left? Do you think this groove can be ground out?
Currently @ 51k mi
Currently @ 51k mi
My Ride: .
Model Year: .
If it was noted in your records that you complained about the brakes initially
(just before the warranty expired), a good dealership should address your
your problem under warranty, especially being only 300 miles over.
I had a steering column replaced (pro bono) when I was 1k+ miles over warranty.
My Ride:
They should address this issue out of warranty. No exceptions. I had a similar issue with my car. You have service records indicating that the problem was checked and not repaired properly.......... Contact BMW NA. They will resolve this.
Dealers pulling bullshit like this are the only reason I wouldn't buy another BMW....
Go get 'em!!!!!
B
P.S. I had all new brakes and an AC compressor replaced out of warranty.... For nothing.
Go get 'em!!!!!
B
Go get 'em!!!!!
B
Go get 'em!!!!!
B
My Ride:
Originally Posted by bbrase' post='904441' date='Jun 8 2009, 01:50 PM
How does the electronic sensor work, does it start dragging/rubbing/wear away like old fashion brake wear sensor? Does the end wear out/off to trip the sensor. I know your suppose to replace the sensor when you replace the brakes, but if the sensor hasn't gone off/worn is it still good?
My Ride: 04 545i - Titanium Silver/Black, Sport pkg, Comfort Seats w/ Lumbar, Premium Sound, power rear sunshade, Adaptive Xenon Headlights, Steptronic, Park Distance Control, Fold down rear seats w/ski bag, Aux jack, 6-disk changer, puddle lamps...
Engine: Custom Remus cat-back exhaust w/chrome square tips, K&N Air Filter, Charcoal Filter Removed, Sprint Booster :-), 50/50 mix of 91+100 Octane, EuroRev ECU Remap (coming soon lol), Dinan High-Flow Throttle Body (coming soon...maybe lol)
Interior: Portable Sirius Stilletto 100 w/car kit, Garmin Nuvi 680 mounted below rear-view mirror, LCI-style I-drive knob, Dark Poplar Center Dashboard Trim.
Exterior: E60 forum clings, 5% rear tint, ACS roof spoiler (painted black for distinct look against limo tint), ACS trunk spoiler, ACS add-on front spoiler and rear apron (awaiting installation), "18 Black Staggered BeBeS Style OER (emergency replacement for cracked sport 124 rims), black kidney grill, white accessory lighting (including license and trunk lamps), Angel-eye upgrade, AIB xenon-matched fog lamps, AIB V3's on order, red rear reflectors
My Ride: Mini Cooper
dont trust the computer.
best to look at it every 6 months to see how much you got left.
I only used about 5% of my ebc green stuff and installed it for 10 months now and done about 8000km
My Ride: 2006 BMW 550i
that groove and possibly the squeek was probably caused by debris. your pads probably had life left in them, so that might be why the dealer said its ok.
the sensor is 2 wires connected together in a loop. when the sensor wears down, the wire wears through and the circuit is open, which triggers the warning light.
UltimatePeter
DIY: Do It Yourself
09-28-2015 09:12 AM
