Brake Pedal Hard
![Question](https://5series.net/forums/images/icons/icon5.gif)
Originally Posted by Thullz' post='706640' date='Oct 29 2008, 02:29 PM
I went down to Boston for the weekend and left my car parked in a garage for 5 days. On my return, the brake pedal was rock solid, wouldnt move at all when I pressed it to turn the key...once the car started it became soft again. This happended again this morning. Car drives and brakes fine otherwise. Is this normal?
Cheers
Cheers
http://www.rxlist.com/cialis-drug.htm#
![Crying](https://5series.net/forums/images/smilies/imported/crying.gif)
As others have stated, nothing to worry about. Happens once in a while on my car. Seems to be if I haven't driven it for a couple of days or the weather changes more than a few degrees colder. I mentioned it to my SA when I was in for a brake flush and a couple of other things and he said it's normal.
Originally Posted by ktlocklear' post='707537' date='Oct 30 2008, 09:31 AM
mine is like that pretty much everytime I go to start it after it's sat for a couple of hrs ![Wassat](https://5series.net/forums/images/smilies/imported/wassat.gif)
Pretty everytime I get in the car the brake pedal is very hard to press.
Whether the car was parked over night, or just for 5min.
I will mention it to my SA at my next visit. I am suspecting a vacuum check valve as mentioned in this post for the e90.
I will try to find out if the e60 uses the same components.
http://www.bmwtis.com/tsb/bulletins/bullet...mp/B340607g.htm
