brake pad shift noise normal?
My Ride: 2010 BMW 550i m sport lci
2010 550i m sport when parking mostly and changing direction wheather its fwd or reverse and the brakes are lightly applied it sounds like the pads shift and make like a medal on medal tap I drove with the tech @ bmw brakes arent due for another 30k and tells me its normal....WTF!?
I work for a Toyota dealer and those shitboxes dont even do that nor does a regular car... what do you think is the dealer B.S ing me?
![Badbad](https://5series.net/forums/images/smilies/imported/badbad.gif)
My 2008 550i does this as well and have taken it to 2 dealers and both confirmed that it is not normal and is exactly what you mentioned, pads shifting in the calipers when brakes are pressed. I bought my car a few months ago and did not hear it until windows were down, and its quite annoying, although both dealers said it is not hurting anything but if I wanted I could replace with OEM pads to resolve the clanking/clicking. I'm sure as I drive it more in he spring weather with the windows down ill probably ending up doing that even though I have about 25k left per the sensors.
My Ride: 2009 535i Sport
Model Year: 2009
Engine: N54
I have the same issue. OEM BMW pads. Never serviced during my owership of the car, still has several thousand miles left on them (per computer/diagnostic screens in iDrive). It only occurs here and there, I'd say less than once a week do I notice/hear it.
I DO NOT think it is "normal".
I DO think new pads would solve it.
car is still under warranty so ill go to them and make em put a new set in I also dont think in any way, shape or form this can be normal....
My Ride: 545i
I'm glad someone brought this up!!
04 545i here and I have the same issues too, it sounds like metal cracking sounds, which occurs when i have the steering wheel cranked either way while backing up into a parking spot.
Annoying as heck since this is a BMW we are talking about.
Will replace with OEM and see what happens.
UltimatePeter
DIY: Do It Yourself
09-28-2015 09:12 AM
TexaZ3
05-06-2015 09:54 AM
