Brake Oil Question
My Ride: 1) 2004 BMW 530IAlpine WhiteLuxury PackageNavigation 2) 2009 Range Rover Sport Supercharged
Hey guys, stupid question i have that needs attention. My Idrive is telling me my brake oil is low(Yellow triangle sign). Now, do i need to add brake oil or change it? Not sure how it works, so someone's advice is requested.
Thanks!
Thanks!
My Ride: e60
its a brake fluid change; like an oil change.
the theory by BMW is that atmospheric factors somehow over time evaporate the amount of brake fluid or somehow adulterates it and the recommended interval is there for changes.
I just had mine done
If your brake fluid is "low" it means you need to add fluid, if your due for an brake oil change it will be listed in your iDrive service menu. Check the service menu of your iDrive and see if your due for a change. If not, then lift the hood and look at your brake fluid resivour, you should be able to see if its within tolerances. If not just add the proper fluid.
One thing to note, if you add fluid you want to add the very minimum to get you back in tolerances, as typically as your pad wear down your fluid level also goes down. So if you fill it to the max and then when you do pad and rotors you'll probably wind up with excess fluid if you dont plan to bleed the brakes.
BTW, I have noticed that my breaks are squeeling also
Yep, probably time for a brake job, sounds to me like your pads are getting close to worn out and your fluid is low as a result. I would take it somewhere and have them take a look at your pads, or you can do it yourself.
GL
Any idea how much a brake job costs out of warranty?
My Ride: 07 E61 530d M-Sport.
The two yearly change interval isn't because it evaporates. Its changed because brake fluid is hydroscopic and will absorb moisture from the atmosphere, this has two results your brake fluid becomes less effective in adverse temps as it heats up and the water can also causes corrosion in the brake system.
My Ride: Type 523I UL (EUR)
Dev. series E60 ()
Line 5
Body type LIM
Steering LL
Door count 4
Engine N52
Cubical capacity 2.50
Power 130
Transmision HECK
Gearbox MECH
Colour TITANSILBER METALLIC (354)
Upholstery LEDER DAKOTA/SCHWARZ (LCSW)
Prod. date 2006-05-15
Order options
No. Description
1CA SELECTION COP RELEVANT VEHICLES
2NP M LT/ALY W. DOUBLE SPOKE 135 M W.RUNFLA
235 TRAILER-HITCH WITH REMOVABLE HEAD
302 ALARM SYSTEM
337 M SPORTS PACKAGE
339 SATIN CHROME
4M3 INTERIOR TRIM.FINI. ALU. CUBE PURE
428 WARNING TRIANGLE
442 CUPHOLDER
465 THROUGH-LOAD SYSTEM
470 CHILD SEAT ISOFIX ATTACHMENT
481 SPORT SEATS F DRIVER/FRONT PASSENGER
494 SEAT HEATING F DRIVER/FRONT PASSENGER
502 ; HEADLIGHT WASHER SYSTEM
508 PARK DISTANCE CONTROL (PDC)
522 XENON LIGHT
534 AUTOMATIC AIR CONDITIONING
540 CRUISE CONTROL
698 AREA-CODE 2
704 M SPORT SUSPENSION
710 M LEATHER STEERING WHEEL
715 M AERODYNAMICS PACKAGE
775 INDIVIDUAL ROOF-LINING ANTHRACITE
8SA COUNTRY SPEC. RELEASE OF NAVIGATION
8SP COP CONTROL
842 COLD CLIMATE VERSION
850 ADD FUEL TANK FILLING FOR EXPORT
863 EUROPE/DEALER DIRECTORY
877 DELETION CROSS-OVER OPERATION
885 SWEDISH/OWNERS HANDBOOK/SERVICE BOOKLET
896 DAYTIME LIGHTS FUNCTION
9AA EXTERNAL SKIN PROTECTION
Series options
No. Description
216 SERVOTRONIC
