Brake booster recall question
Old Aug 31, 2015 | 04:16 PM
turbo_mustang12's Avatar
Default Brake booster recall question
So I've already relaxed my brake booster once 5 yrs ago when the car had about 60k miles and now that it's at 103k miles it has went out again. There is a recall from bmw but it's a hose. If this "hose" does not fix it is bmw still liable to fix my brake booster since the oil dripping in the brake booster due to a fault hose probably ruined it?
Old Sep 1, 2015 | 07:48 AM
rice_rocket88's Avatar
My Ride: 2008 535xi
Engine: n54
I'm a little unclear since I actually didn't do this or know about it.
But.. if the recall was simply for a hose to be switched, and now it's leaking again.. I doubt that it's part of any warranty, it's called wear and tear. If you're lucky and you have an extended warranty, I can't remember the verbage, but mileage is supposed to be 110K ? So you'd just squeak under it. But years wise you might be over..
Old Sep 2, 2015 | 10:46 PM
H F's Avatar
H F
My Ride: 2005 545
The recall is for a bad design hose that leads from the vacume pump to the brake booster. And oil passes into the brake booster . The new one has a valve that will not let oil pass into the booster . When they perform the recall fix , if they find that oil has entered the brake booster , they will replace it .. From my understanding this only applies to the V/8 engines .
star69me
Jun 17, 2015 07:40 PM
windnsea
May 25, 2015 09:49 PM
MCarr
May 19, 2015 01:12 PM
thesalboy
Apr 8, 2015 09:13 AM
brian1225
Apr 16, 2004 05:59 AM
