Both seat heaters & steering column adjuster failed.....help.
Both the left and right seat heaters and the steering column adjuster stopped working at the same time on my 2005 530. I checked the fuses for the seat heaters and they are both ok. I then checked all of the other fuses (glove box and trunk) and found none blown. Does anyone know if there is a relay or power distribution module that these circuits share or some other component that could cause this failure?
Thanks in advance for any help you can provide.
jeffandjaimie
07-08-2015 05:48 PM
