BMW e60 Inpa active steering codes
So recently my bmw 525i the steering light came on, also the idrive system has a pass. restraint system code. I scanned the car with inpa. I scanned active front steeringoption in inpa. Inpa found 5 codes and the codes are 6145 none monitor the total relationship
614a engine position angle not initialized
ce93 message(steering wheel angle top, id=0c8) initialization phase
ce99 message (steering angle angle top, id=0c8) from s2L f-can
6140 redundancy comparison driver steering angle top
any ideas on how to fix this?
My Ride: 2004 545i+BT+AUX+Coding
Engine: N62
Try to initialize by turning wheel all the way side to side, let car go to sleep and see if codes come back,(delete existing codes first)
Engine: N62
Either with INPA or DIS you can do some stuff to try like initialize and or correct steering angle sensor
I have done mine with DIS but depending on what version of INPA you have you can do some of then with INPA as well.
IIRC there are some YouTube vids out there to guide you along.
EDITED
You can also disconnect battery for a while and see if steering comes back normal.
EDITED
Engine: N62
https://5series.net/forums/e60-discu...-107051/page2/
And here’s the PDF of my screenshots I used, cannot guarantee it’s all on the right sequence.
Sorry can’t upload it right now, will try tomorrow,
Edited:
Motopokep, I sent you a private msg.
Engine: N62
I posted a YouTube Here:
Edited:
Edited:
HTH
https://www.dropbox.com/s/yaol2k935f...%2018.pdf?dl=0
