BMW E60 CCC DVD Drive removal and replacement
Hey Guys, thought id put up a DIY of how to remove and replace the DVD Drive from a 2005 CCC.
Not sure if there is already a DIY up or not but hey thought i might aswell post it and help fellow forum members out, its been a very long time since i have posted since my E60 got stolen last year. But still come visit to see how my fellow E60 buddies are doing.
Basically what happened is my mates E60 CCC fried up and was overheating as when hooked up on through DIS it came up with internal overheating problem.
Tried changing the fan in the back of the CCC with no luck, still overheating.
So he bought a used CCC off a breaker but the a$$holes CCC DVD Drive was faulty and would not read DVDs or CDs so the only other option was to remove the DVD from his and replace it with the other one as the other CCC was fine but DVD faulty.
Please see pictures for reference.
1) You disconnect the battery
2) You remove the CCC (please search the forum to see how you remove the CCC, Dash Trims)
3) Remove the front fascia ( black trim with the DVD CD and Eject button (two black hex screws holding them together)
4) Once the CCC is out you remove the top plate and you will see two small silver hex screws ( they are the two silver screws which you can see when looking into the CCC by looking into the CCC from the top.
5) After removing them screws you have two silver hex screws in the front of the CCC holding the DVD Drive. (Once removed just slide the DVD Drive out from the CCC, be carefull when removing not two pull too hard as you wil rip the cables)
6) Once the DVD Drive is out remove the cables ( one is a pop out cable while the other you have to unlatch the holder to the cable, also different CCC's have different types of latch as one of the CCC had a latch which popped up while the other had a slide off latch)
7) After that just swap over and work backwards on the steps above also be carefull with the cable when sliding the DVD Drive back in.
In my case I had to use NCS expert to code the new CCC back to my friends cars options using the VO off my mates car so im sure some of you guys know how to do that. I also changed the VIN on the used CCC to my mates VIN.
Anyways happy DIYing and message me if you need any help.
Hi , Did you have to recode the car after replacing CCC? I am in a similar situation. My Idrive screen in black and dealer told me i need to replace my CCC and it would involve coding.
I used NCSExpert to load back to my friends settings by using the cars VO.
Everything took me about 45 minutes to do as i knew what i was doing.
Also I changed the VIN Number on the used CCC which he bought.
Best thing would be to buy a used CCC from a reputable breaker and then go from there. Make sure you dont find a breaker like my friend did as he was an ass because his DVD drive wasnt working hence why i changed it but the CCC itself was fine.
My Ride: stock e60
Hi Ankur09, Yes it required coding with NCSexpert.
BYS2
03-24-2015 03:13 AM
