BMW E60 2007 Side lights error/fault code?
My Ride: BMW
When side lights are turned on, the drivers side is not working, should I receive an error/fault code for this? I've checked idrive and check system and it shows 'no faults', but I was curious to know if this should have flagged up. I will be changing the bulb at some point soon for some decent Angel Eyes, so if anyone can recommend nice bright white bulbs (not blue). the car is BMW 520d SE 2007 E60 saloon. Thanks
100% d'origine lancement launch CReader Professional 129 CRP129 peut réinitialiser bloc de frein, Capteur d'angle de braquage corect, Réinitialisation de la lumière de l'huile moteur
Tsoup
15
Dec 20, 2021 11:14 AM
SFx550i
Apr 14, 2015 05:00 PM
