BMW 520d lci n47d20a loosing coolant
Old Oct 18, 2021 | 12:35 PM
Fivethreefive's Avatar
My Ride: Bmw 535
Default BMW 520d lci n47d20a loosing coolant
Hi
my e60 520d lci with 200,000 miles is loosing coolant, this happened 2-3 times coolant too low sign came on, filled up and gone low again after 100 miles
No visible leaks, but I can see some white smoke from exhaust sometimes when pulling away, also egr valve vacuum got siezed so I changed egr, water pump and new coolant but still the same. The radiator hoses are hot and very pressure seems like system is pressuring, can hear the coolant bottle trying to release pressure
any ideas please
Old Oct 18, 2021 | 12:50 PM
seanjordan20's Avatar
Engine: 3.0 B58; 3.0 M54
I would do a pressure test on the system. You'll definitely find it then. I know the N47 had a recall or something on the EGR due to coolant leak issue but that can't be your issue.
Old Oct 18, 2021 | 01:44 PM
My Ride: Bmw 535
pressure test will find the leak ? But wheat about the pressurising coolant system, if there was a leak would it not build that much pressure ? The pipes are rock solid when runing
Old Oct 18, 2021 | 09:24 PM
donpb's Avatar
My Ride: '06 530i N52
The leak appears to be internal. Pressure test to verify.
Old Oct 19, 2021 | 02:29 PM
My Ride: Bmw 535
Sorry what do you mean, I’m suspecting head gasket or cracked head/block, how will pressure test prove this ?
rev run d
Jun 18, 2017 07:07 PM
westsidebalto
May 12, 2015 04:54 AM
undacovalova
Feb 19, 2013 06:11 PM
Krozi
Apr 16, 2009 04:38 PM
545insc
Jan 29, 2009 07:32 PM
