Bimmer won't start need our forum gurus...
#22
Given that you've installed new battery, starter solenoid seems to be engaging, and fuel pump seems to run (fuel pressure is not a concern just for the starter to engage, so let's not worry about fuel pressure at this time), I'd say the starter is dead.
Search the forum, you will find couple of threads on starter replacement.
#23
My Ride: 2006 e61
As troublesome and frustrating as this is, I am at least thankful for having this forum full of awesome members that are willing to respond and help. Much appreciated!!
My next questions is is there anyway to test the started or read a fault code that will for sure tell me... Thats my issue???
The starter is buried under the intake manifold and is quite the job. I want to make sure that is the issue before I dive in.
What kind of sings does the car give if the immobilizer is activated and my key isn't working for some reason? Does anything pop on the dash I need to look for?
#25
My Ride: 2006 e61
2006 530xit w/ 60k miles
When I engage the car has 1 click its very faint, and then a long hum for a few seconds and then nothing... All of the lights work fine there is no dim nothing...
#29
My Ride: 2006 BMW 550i
can you get access to the starter? verify if the wires are bolted good and have voltage there?
sometimes you can get a stubborn starter going by tapping on it. use some socket extensions and a hammer and tap it.
