Big Key Problem!!!!!
Originally Posted by EBMCS03' post='514250' date='Jan 6 2008, 02:24 AM
Your car a 2004? that means you still have the metal "key" right? if so try these steps... <--- this is the reason people need to add their car information in their signature. Otherwise we cannot answer questions correctly...
Get in your car
press unlock button 4 times
make sure car is unlocked w/ doors closed
turn on ignition
turn ignition back off and take they key out
hold down unlock button and press lock button 3 times
and the locks will cycle if you did it right
for 2nd key just hold down the unlock and press lock 3 times
no need to cycle ign for the second or third keys
Get in your car
turn on ignition
Thanks
Mike
Originally Posted by mk23169' post='514395' date='Jan 6 2008, 10:31 AM
Didnt work....Thanks for the tip though. It must be that the key shorted!
Thanks
Mike
Thanks
Mike
Hummm those instructions might not be 100% correct... I guess it might be best to go let the dealer check it out.
Wonky
Apr 12, 2016 08:15 PM
