best 0-60 time
Old 10-22-2008, 08:50 AM
  #21
grogan545's Avatar
My Ride: 2008 550I,manufactured 2-27-08,delivered 4-2-08.Platinum bronze,natural brown interior,light poplar trim,cold weather package,heated rear seats,HD radio
Originally Posted by Ricracing' post='699962' date='Oct 22 2008, 11:31 AM
Very nice time!
I suppose the track had glue on it?
What rear tires?
Manual trans, I guess, but at what point was the gear change from first to second?
Time was done on a road that I test on.I have found it has better traction than at my local drag strip(Maple Grove,Pa).Best 60' time at the drag strip was 2.02,best 60' time on my test road was 1.91.This was done on my 545I.I am completely stock 550I including the goodyear RSA tires.I have a steptronic which is faster for acceleration due to the favorable gear ratio's in 1 thru 4,and also the rear ratio,3.38 vs 2.91 for the manual.The 4.67 run was done in cold dry weather which is very good for making power.My step shifts at 6700 rpm's in all gears.This is 200 above redline.My previous car was a 545 step and that shifted right at 6500 rpm's.I believe Motor Trend tested a 550 manual and got 4.85 sec 0-60 and 13.31 for the 1/4.They correct for weather conditions so my time is not totaly out of line.
Old 10-22-2008, 09:00 AM
  #22
CWS530's Avatar
Very nice data! Thanks for sharing/making me jealous!
Old 10-22-2008, 09:05 AM
  #23
Ricracing's Avatar
I suppose 200 rpm above the normal max rpm is optimum for the 550i.
Your rear ratio is not standard. Do you have a opened air intake?
You didn't answer my q about the rears, 275's or 285's or racing slicks?
Well done anyway!
Old 10-22-2008, 10:00 AM
  #24
E60714's Avatar
Doesn't BMW understate their performance numbers? the 550 should be 5.2 or below, but I have seen car mags get 4.8. I think it was C&D.
Old 10-22-2008, 12:50 PM
  #25
cobradav's Avatar
Well done anyway!
Yes, that rear ratio is as advertised for an automatic transmission. Both the older 545 and the newer 550 use the same ratio. Also calculates correctly for each tranny gear and RPM. I have the tables built that coorespond to these ratios.
Old 10-22-2008, 01:24 PM
  #26
Brit_in_NJ's Avatar
My Ride: '05 545 Titanium Silver, Black Leather - Nav, Logic 7, Cold weather. Mods: Carbon filter removed. M5 iDrive knob. Umnitza license plate LEDs. MP3 40% 3M tint ACS Anti-Roll(sway) bars RPI Scoop G-tech Pro RR CF Roundels CF Wheel caps
Well done anyway!
He said his car was "stock" meaning no mods...even the tires.
Impressive times...now I want to mod more...hahaha
Old 10-22-2008, 01:41 PM
  #27
Aartsy19's Avatar
Originally Posted by grogan545' post='698919' date='Oct 21 2008, 12:46 PM
In my weather conditions the M5 would be close to 4 secs flat.
STOCK?!?? Stock the book says 4.4-4.6 0-60....
Old 10-22-2008, 02:14 PM
  #28
miguex's Avatar
Location: Calgary, AB - Canada / Buenos Aires - Argentina
My Ride: 2006 BMW M5
Yeah he said full BONE STOCK!
remember 545 /550 have equal HP=TORQUE
M5 has much less TORQUE than HP 507 HP / 384 ft Torque.
Same HP and Torque = more quicker. but the M5 will smoke easily 545/550 after 0-60
Imagine M5 has same HP = Torque, it would be less of 4 secs. for sure!
Old 10-23-2008, 07:04 AM
  #29
grogan545's Avatar
Well done anyway!
The 3.38 gear ratio is standard in the steptronic.Tires are 225/50 17" Goodyear RSA.These are also standard with the 550 without the sport package.
Old 10-23-2008, 07:08 AM
  #30
grogan545's Avatar
In cold dry weather the times would be close to 4 secs flat.All magazines correct for weather conditions.Weather can vary HP output by 50-75 HP on a 500 HP car
Quick Reply: best 0-60 time
