Battery Safety Terminal?
Old 06-08-2012, 08:56 AM
  #41
bubba43's Avatar
Thanks, i will try this and post results
Old 07-06-2012, 06:50 AM
  #42
bubba43's Avatar
Follow up to the BST. I had All German Auto read the codes and perform a reset. So far the fault has not come back. I am now convinced that this was a bad connection at the trunk terminal and was corrected during the recall. Brecht BMW should have reset this but wanted to charge me $500 to do this.
Old 07-06-2012, 09:54 AM
  #43
balbs's Avatar
My Ride: BMW
I bet it was probably dirty connections causing a higher resistance.
Old 07-20-2012, 04:56 PM
  #44
E60COYOTE's Avatar
Had the same air bag light and error and found this post. Changed the BST cable, cleared the code, and all is well. Removed the rear seat to get the the trim/floor panels better.
Thanks to all who posted here. I love this forum....
Old 07-21-2012, 10:01 PM
  #45
louisrai's Avatar
My Ride: 2008 BMW 535i Silver - E60
How did you replace the BST cable? DIY or dealer? How much did you spend on that replacement? Thanks! I've been told this could be a 5-hour work.
Old 07-22-2012, 04:45 AM
  #46
E60COYOTE's Avatar
I did it myself in about 1 hour 30 minutes. It was very easy. Used the TIS in this thread and removed rear seat. Hardest part was getting the seat back back in. Had trouble getting the 2 lower srews snugged up. I used INPA to reset the code. The cable was $218 plus shipping from one of our friends on this forum.
Old 05-05-2013, 11:18 AM
  #47
kalafior's Avatar
My Ride: bmw e60 525d
Default Dan
BMW 5 Series E60 Positive Battery Blow Off Cable SBK
if I buy this cable somewhere in the uk
Old 08-03-2013, 11:49 AM
  #48
Benspriggs's Avatar
My Ride: 1999 M Roadster
I am having the same problem in a 2000 M Roadster, I am sure it is the BST. Can't find the specific part for it. ANyone have any experience on M Roadster, Coupe or Z3? Can I use the same cable from a 3- or 5-series?
Vman33
03-14-2022 04:43 AM
BuddyB
08-17-2017 12:48 AM
derooster
09-22-2016 07:30 AM
LandRange
10-05-2015 08:47 AM
LandRange
09-06-2015 10:39 AM
Quick Reply: Battery Safety Terminal?
