Battery Registration Too Much Info
#51
My Ride: 530d msport Lci 2007
If the car starts in the morning I’m not interested in a true battery at rest reading, i can make comparisons from an ignition on engine off situation, it should be the same everyday,
#52
My Ride: 528i
Model Year: 2010 528i e60
Engine: N52k
Regarding you doing parasitic draw tests with an external multimeter, if you go back and research parasitic draw you'll find a lot of people did a ton of diagnostic work that was not conclusive.
However, there appears to be a common theme on the various forums in the parasitic draw saga.
That is, when the car is off and asleep, feel which relay is warm to hot. This unlocks the mystery.
Many times the issue was the 30g terminal.
#53
I am first going to do the test where you see the draw when or if the car goes to sleep (60-70 mins),
#55
More details...
1. Battery was fully charged to 12.6v with no errors.
2. Removed for three days and measured 12.5v.
3. Installed it in the car today, drove 2 miles round trip.
4. Did a load test, headlights, fan, music on for 1 minute with engine off, battery measured 11.75v.
5. Turned headlights off and measured 12v.
I think I may have a weak battery, date code 11/18. I have a 3yr free replacement warranty. Back to the store it goes.
#56
More details...
#57
My Ride: 528i
Engine: N52k
Remember my big idea from last week?
In your lower parking garage there is a ceiling light.
Tap into that ceiling light and install a 110v socket for your battery trickle charger.
Don't worry about the leasing office. They haven't been in the garage for 20 years.
#59
