Battery Registration Too Much Info
Old 09-29-2020, 09:57 PM
  #41
donpb's Avatar
My Ride: '06 530i N52
I've charged the battery over night and am letting it sit to measure storage voltage. It's sitting at 12.8v right now. Then I'll put it back in the car and check for parasitic draw. I'll read the alternator output again with the battery fully charged.
Let's not get all fixated on my 14.1v statement. I recalled that from memory. It could actually be higher.
My battery doesn't always exhibit low voltage. Just every once in awhile. So I'm not going to fly out and replace the alternator. I'm following the Bentley manual procedure. This isn't rocket science.
Old 09-29-2020, 11:59 PM
  #42
Redballs1's Avatar
My Ride: 530d msport Lci 2007
I’ve got a small led voltmeter that plugs into the cigar lighter, when i was having problems i left it in there so i could monitor charging voltages over a period of time, i got it off ebay for peanuts, definately worth a buy.
Old 09-30-2020, 05:30 AM
  #43
scottalexander's Avatar
My Ride: 528i
Model Year: 2010 528i e60
Engine: N52k
Can you send us a link to the item you bought off eBay (that plugs into the cigarette lighter)?
Do you recommend that model?
Old 09-30-2020, 06:26 AM
  #44
Redballs1's Avatar
273246877930 is the item number on ebay.co.uk or the description is 12V/24V LED Car Cigarette Socket Voltmeter Voltage Battery Tester Detector Meter, i’ve even cut one down and made it a permanent fixture, i’ll post a picture later, for the price of these they should be in every toolkit
Old 09-30-2020, 08:27 AM
  #45
Redballs1's Avatar
Old 09-30-2020, 08:45 AM
  #46
My Ride: 528i
Engine: N52k
Nice pic.
I'm going to buy one of these volt meters.
What I'm interested to see is how often that 14.8 number fluctuates as I drive down the street.
Old 09-30-2020, 09:18 AM
  #47
Redballs1's Avatar
Mine usually is consistent at 14.4V but does fluctuate up and down, It was reading 14.8V here because I had just started it after a period of standing with the ignition on. I don't get concerned at fluctuations of .4V For me it's an early warning of a total charging failure. There are other variations of plug in voltmeters on ebay but this one does what i want it to.
Old 09-30-2020, 11:08 AM
  #48
FormerE30Owner's Avatar
My Ride: 2005 545i, premium package, 6sp manual, cold package, navigation package.
Model Year: 2005
Engine: N62
I have the same feature on my radar detector. One problem, though. The car cigarette socket is active only in the accessory or engine running position. One cannot see the voltage on the battery when the car is not running. When the key is in the accessories position and the engine is not running, the battery is connected to all the "stuff" and the reading shown is not that of the unloaded battery. One must take the reading at the battery terminals with the key out to get the true "battery at rest" reading..
Old 09-30-2020, 12:29 PM
  #49
donpb's Avatar
I did a search on eBay for "cigarette lighter voltmeter". There's oodles of them.
Old 09-30-2020, 12:32 PM
  #50
donpb's Avatar
And that's why I'll be performing the parasitic draw test with an external multimeter.
FormerE30Owner (09-30-2020)
Quick Reply: Battery Registration Too Much Info
