Battery Issues
#31
I have an 05 530i (same engine) and had to diagnose a similar no-start issue earlier this year. There is a way to reach starter solonoid terminal without having to remove anything - I am not near my car, but if I remember correctly, you have to stand on the driver's side, reach over the fender and reach deep down into the top of the transmission housing which is close to where the starter is attached to. You can then get a volt meter/multi-tester and place one lead the starter solonoid terminal and ground the other tester lead and have someone turn the key to the start position and see voltage is being sent to the solonoid. When I was diagnosing my no-start, I did see voltage at the starter when the key was turned and was therefore a bad starter.
#33
My Ride: BMW E60 M5
Model Year: 2010
Engine: S85
DavaiLave
08-02-2022 02:16 AM
spitfire23
05-12-2015 04:23 AM
