Battery Drained, warranty wont cover. $360
My Ride: 2007 530xiT, 1964 MBZ 220SEb Coupe, 1986 MBZ 300E and a 1997 Jeep Cherokee as my cottage car.
Previous rides started with a 1947 Studebaker Commander convertible and included numerous Fords, VWs, MBZs, Saabs and, for added measure, a '61 Buick Special Wagon and Pontiac GTO.
Originally Posted by exx1976' post='779560' date='Jan 28 2009, 03:00 PM
What about maintenance?
Al T.
nope not on there either. Idrive will never tell you that you need a new battery. Youre dead car will.
I'm not sure, but I thought my cigarrette lighter sockets were switched 12 volts. If that is the case, unless there was a failure of a electronic component, relay or switch the battery shouldn't see a load and be drained when the car is off. If that's the case then you might be able to get the failed component and battery replaced under warranty. I had the dealer replace two batteries under warranty. Batteries are not designed to do complete discharge and recharge cycles. Everytime that happens the battery is stressed and possibly degraded wrt available cold cranking amps. If there was a failed component that did not switch off the 12V to your lighter and as a result drained your battery, it could have permanently damaged your battery. Just a thought, based on the assumption that the lighter socket is switched. Good luck.
they shpuld change and give you a new one, i had mine changed last week, it always pays to be nice to you SA, thats what i do, i gave him a gift last christmas
good luck!!
Originally Posted by PraiseTheLowered' post='779458' date='Jan 28 2009, 01:53 PM
You can try that but they dont cover batteries on the OEM warranty or CPO.
Originally Posted by unknown' post='780329' date='Jan 29 2009, 11:58 AM
batteries are covered... Attachment 70602
Wow you are right, it is covered under the new vehicle warranty. I missed that.
EDIT: Nevermind. I just read down (or up depending on how you look at it).
Originally Posted by CWS530' post='780446' date='Jan 29 2009, 02:26 PM
I thought it was bumper to bumper for four years on a new car? Why would batteries be excluded?
My Ride: 2004 BMW 545i Sport Package, Titanium Gray II Metallic, Wheel Style 124
no bad i paid $400 for mine never had a dead battery since
Germaniks
08-09-2015 10:46 AM
srogers535x
08-05-2015 08:48 AM
Kbc
07-27-2015 05:51 PM
