Battery drain
Old Jan 7, 2023 | 09:33 PM
Chrissee's Avatar
My Ride: E60
No i haven’t disconnected the Ibs yet. At the moment ive disconnected the battery and put it on charge.Are you saying that although it’s a new battery that it might not be charging properly? Could all the times that the car have discharged the battery damaged the new battery?
what do you suggest I do:shall I charge battery and the disconnect Ibs and see go for a long drive and switch car off and see if problem persist?
Thank you so much for all your help.
Old Jan 7, 2023 | 09:52 PM
donpb's Avatar
My Ride: '06 530i N52
If you did not register the new battery, it'd be at a charge rate for an old battery which is good for an old battery, but not so good for a new battery.
It can damage a new battery, but it takes a bit.
Since you don't seem to even have a multimeter, I was about to reply to fully charge the battery, and then disconnect the IBS and see what happens.
Old Jan 7, 2023 | 10:02 PM
Chrissee's Avatar
My Ride: E60
Thank you.
I’ll do that. And get in touch with you probably after couple of days.
I have the old bmw version, do I register the battery with any software? I Google it and nothing comes up about registering new batteries for 54 plate 5series e60
Anthro
Feb 11, 2021 07:51 PM
b21playa
Jun 29, 2015 04:23 PM
lcc014
Sep 8, 2011 03:34 PM
jetblack3s
Jan 10, 2011 04:39 AM
mels545
Nov 12, 2010 03:57 PM
