AUX Bass and Sound Quality Problem Solved!!!
#51
This seems to be a great solution (removing these resistors), but I would try to connect a Iriver mp3-player, which has a non-balanced line out (so output power mounts with the volume) which gives more or less 900mV(L) + 900mV?, (47KOhm) at Max. Volume.
Any risk if the resistors are removed to harm the audio system ?
#52
My Ride: 2004 530i 6-speed Titanium Silver/Black Interior
Premium Package
Sport Package
Aux input
30 GB video iPod
Cold Weather Package
Xenon
Red rear reflectors
Tint
Clear Bra
Anyone have more tips on removing the glove box? I removed the screws in front and sides but could not pull down the glove box.
#53
Originally Posted by singhss' post='256954' date='Mar 18 2006, 09:04 PM
You can make your own setup if you want to, and avoid purchasing the BMW Aux Input cable. I bought 100 of the proprietary terminal connectors from Tyco electronics(which is the OEM supplier of this part to BMW) that connect to the back of the CCC.
To DIY you will need 3 wires for the aux input (Left,Right, Ground). I have made this harness for a bunch of people and they work great. All you need is 3 good quality wires, 3 terminal connectors(the Tyco ones) to plug into the CCC, and the 1/8" female jack from Radio Shack (I think it was like $2-3). You just solder things together and get the dealer to program the Aux Input to the Vehicle Order ($30-$45) and you are all set.
Let me know if any of you guys want the Tyco terminal connectors that fit the back of the CCC to DIY, cuz I got plenty to sell.
#54
My Ride: 2006 BMW 525i - Silver Gray Metallic - Black Leather - Poplar Trim - Steptronic - Sport Package - Premium Package - Xenon Adaptive Headlights - Satellite Radio Prep - Rear Bumper Reflectors
Once the screws are removed, the compartment should be loose. You should be able to at least pull it down a few inches and notice that there are two plastic hooks, one on the left and one on the right that are still holding up the compartment. Disengage them and you should be able to pull the compartment down more... just enough to be able to reach for the cables in the back.
Good luck!
#55
My Ride: 545i 6spd manual. Euro Delivery, Nav, Sport Pkg, 35%Johnson Tint
When i did the aux install I didnt have to remove my glove box, I simply undid those straps on the side and that gave it the extra few inches I needed to drill holes for the jack.
#56
Premium Package
Sport Package
Aux input
30 GB video iPod
Xenon
Red rear reflectors
Tint
Clear Bra
Originally Posted by PotatoAddict' post='257965' date='Mar 21 2006, 03:48 AM
There is also one more screw on the bottom of the box in the passenger's footwell on the left... did you remove that one?
Good luck!
Good luck!
#57
Originally Posted by needforspeed' post='253609' date='Mar 12 2006, 05:03 AM
Don't tease - how do I do this please?
I've managed to get - 'ok' - bass response, but have been considering trying to re-equalize all of my MP3's - where are the capacitors and resister thingys?
Nice job.
#58
Originally Posted by acribb' post='258169' date='Mar 21 2006, 10:54 PM
All I got to say is that "You are the man!". I've been wanting to do this for a while, just haven't gotten around to it due to other life priorities. I pretty much had just stopped using my iPod in the BMW since it was such a crappola sound. I even posted several times about it and always got the response of "mine sounds fine", yadda, yadda, yadda. I'm glad everyone here in this thread realizes the sound degradation from the factory aux input and that you had the balls to do something about it.
Nice job.
Nice job.
Same here : works great - sound is super !!! Had easy access since I did only have to loosen the jack connector plate and pull about 20 cm of the cable out.
Still a little bit afraid of the consequences given the removal of these parts. What could be the worst case scenario if the input is too high ? What is the value for which the main system is designed ? Any ideas ?
#59
I've also taken the precaution of using MP3gain to reduce / level the volume of all of my tracks to 89dba. This means there is a large discrepancy between the volume of my ipod and the radio / cd, but it's worth doing to be absolutely certain that you will not damage your amp or speakers.
#60
My Ride: 2007 530xi - Silver/Gray, Gray Leather, 6 SP Manual, Premium, Sport, CW, CA, Shades, Logic7
So does anyone know if the standard aux input on the 2007 (US) models will be any different (better)? Or is it basically the same setup, just now integrated in the console and standard?
