AUX Bass and Sound Quality Problem Solved!!!
Old 03-13-2006, 01:04 PM
  #21
Busta's Avatar
Awesome find...works GREAT!!! Everything I was missing (bass) is now there.
After unscrewing the aux face plate I was able to pull out enough slack out of the aux wiring...That I did'nt need to take apart the glove compartment. I pulled out the wiring...the caps/resistors are about 3 inches from the end of the cable. Spliced them out and it works perfectly. I highly recommend this mod. Everything took less than 15minutes to complete
Old 03-13-2006, 02:07 PM
  #22
my530i's Avatar
Should we make this as Sticky? I vote "Yes"
Old 03-13-2006, 02:10 PM
  #23
Busta's Avatar
I'm with you. YES.
Old 03-13-2006, 02:41 PM
  #24
bruce_miranda's Avatar
Originally Posted by my530i' post='254243' date='Mar 13 2006, 06:03 PM
Caps and resistor are there serve as high pass filter which pass frequency higher than the one specified.
Take a look at the circuit below and you see what I mean. The reasons they are there are to reduce gain coming from headphone jeck instead of line-out, and filter out low frequency. The second reason is the side effect of the first one.
We should suggest to BMW that they now upgrade their AUX kit to include a Low/High pass filter toggle switch similar to ones found on many older amplifiers. That way people don't go out cutting their cables to bits.
Old 03-13-2006, 02:56 PM
  #25
my530i's Avatar
This will make this AUX cable cost $200
To be honest, we can make this cable for less than $15 with BMW connect pin.
Old 03-13-2006, 04:52 PM
  #26
PotatoAddict's Avatar
My Ride: 2006 BMW 525i - Silver Gray Metallic - Black Leather - Poplar Trim - Steptronic - Sport Package - Premium Package - Xenon Adaptive Headlights - Satellite Radio Prep - Rear Bumper Reflectors
YES!
Old 03-14-2006, 12:35 AM
  #27
needforspeed's Avatar
I'm going to try this at lunchtime and if it works (and I don;t break my car) then it should be VERY sticky.
Old 03-14-2006, 05:39 AM
  #28
The first time it you'd take you 2 hours, but the second time, it might take you only 20-30 minutes.
To avoid clipping, set your MP3 equalizer to flat if you connect to your MP3/iPod/DVD player headphone jack.
I'm glad that people are happy with the outcome. Let me know if you guy have any question.
Just done this in my lunch hour - took me about 25 mins
When it came to cutting the wires I was somewhat nervous, but it works a bloomin treat.
530i and Potato Addict - you are lovely people
Chaps like you MAKE this forum a simply STUNNING resource.
One question - I'm using a proper line out - sound is OK with the EQ off, but is FANTASTIC with it on 'bass booster' (my IPOD usual setting) do you see a problem in running it this way?
I've only used in briefly, but there is no evidence of distortion etc, so it seems unlikely that I am overloading the system.
Thanks again - you guys are heroes
Old 03-14-2006, 09:10 AM
  #29
my530i's Avatar
Too much bass boot on your iPod might cause clipping on some instance. Use flat is the best for be so far, and I just crank up the volume.
Old 03-14-2006, 01:56 PM
  #30
subterFUSE's Avatar
Use the EQ in the Logic 7.
Quick Reply: AUX Bass and Sound Quality Problem Solved!!!
