Auto leveling vs Adaptive headlights?
Old Feb 21, 2011 | 04:01 AM
xcntrk's Avatar
My Ride: 2008 550i Sport
I?m the second owner of my E60. I don?t have the original window sticker or clear description of what options the car came equipped with when originally built. I have Bi-XENON headlights with auto-leveling and they work fine. On startup sequence they go up, down, then auto-level somewhere in-between depending on load.
My question is; what?s the difference between auto-leveling versus adaptive? I know adaptive turns left/right based on steering input ? but is it possible I have these and that feature is disabled, malfunctioning, or simply needs to be coded? Or is auto-leveling vs adaptive two completely different features altogether?
Old Feb 21, 2011 | 04:06 AM
Vista's Avatar
Your headlights will only alter the beam angle if left in the auto mode. Try parking up close to a wall and turning the steering wheel with lights on in auto, you should see the beam move. Note also that they don't move in both directions, only in towards the kerb (different depending on whether you're in a LHD or RHD vehicle)
Old Feb 21, 2011 | 04:28 AM
ProMed's Avatar
My Ride: 535i
Correct, unless you are going greater than 15mph.
Old Feb 21, 2011 | 04:38 AM
Hyper_545i's Avatar
My Ride: 545i
Engine: N62
As mentioned earlier, you will need to put your headlights in "Auto" mode. The headlights will turn with the steering input and auto level as necessary. Note, the headlight will only turn to the right (on LHD Models) and not the left if you are parked or stationary to avoid blinding oncoming traffic. So you have both.
Old Feb 21, 2011 | 04:59 AM
luigi524td's Avatar
A BMW dealer SA, with your proof of ownership [registration in your name] , can provide you with a build sheet indicating car configuration at time of delivery. If any additions were made by BMW that will also be reported in the vehicle history.
I'm really surprised that buyers of pre-owned BMWs* aren't aware this information is readily available.
*Or, for that matter, almost every brand of vehicle sold ..
Old Feb 21, 2011 | 10:05 AM
xcntrk's Avatar
Oh now I feel silly! Great information - thanks all. I didn't realize this was simply one of those RTFM moments!
I thought I did scourer the owners manual about this subject but clearly I missed the "auto" only switch position mention and coincidentally I never use auto mode.
My stealership did review all the vehicle features with me when I switched over the BMW assist service subscription. Turns after (after investigating following this thread) that the reason it's not listed in the options is because it's a STANDARD feature on the 550i...!
Doah
Old Aug 16, 2011 | 03:02 AM
NguyenAzn's Avatar
My Ride: 525i
Sorry to bump an old thread, but i have a pre lci with non projector headlights ! Any of these options would apply on my model 07 ?
Old Aug 16, 2011 | 03:13 AM
nomis_nehc's Avatar
My Ride: BMW E60
Model Year: 2016
No.
Skaper
21
Aug 30, 2017 06:54 PM
umnitza
Apr 6, 2017 02:59 PM
umichchris
Dec 10, 2015 01:00 PM
Lotus99
Jul 2, 2015 02:14 PM
Hyper_545i
Jul 1, 2015 05:07 PM
