Aussie 2004 530i - Stereo with no sub amp?
Old Jan 21, 2012 | 11:25 PM
pauly_2's Avatar
Hi - Be kind to the newbie please.
I've recently picked up an e60 2004 530i - Great car - Except for the stereo :-(.
SO.. I've done a heap of research and thought replacing the Sub amp on the left hand rear wheel well would be a great first step - Removed the trim and no amp!... What gives? I do have the subs under the front seats, and they are working. Is this some sort of unusual standard setup for the Australian market or something?
Thanks for any advice.
Pauly2
Old Jan 22, 2012 | 12:18 AM
nevrev73's Avatar
My Ride: 2008 530d M sport
Hi! You must have what I had in my old 2005 BMW 530i Mpsort.
It had a standard system in but no amp. You probably also do not have door tweeters even though the grills will be there.
These can be added and do make a difference.
They are ways to add a sub on your system, do a search on here how to do it.
check out this post for some links....
https://5series.net/forums/topic/120...runk-question/
Old Jan 23, 2012 | 12:34 AM
pauly_2's Avatar
G'day Nev,
Thanks for the reply. - What a let down... buy a nice Euro vehicle - and it comes with _that_! Unbeleivable.
Guess I'll have to start surveying my options.
Pauly_2
Old Jan 23, 2012 | 02:11 PM
mporange's Avatar
I have that system :thumbsdown:
Two 4" fulltone in the rear deck and front doors. And two 160mm subs under the seats.
I have fitted a Blaupunkt pnp 475 amp that helped a bit. About to the replace the speakers with some quality ones.
Old Jan 23, 2012 | 03:56 PM
pauly_2's Avatar
BHi Mporange,
Thanks for the reply - What did you connect the amp inputs to?
Thanks
Pauly_2
Old Jan 23, 2012 | 11:32 PM
pauly_2's Avatar
Oh - Also, are you sure they are 160mm subs, or is that a guestimate? The reason I ask is that all other sources are saying 203mm (8") - Thanks
Pauly_2
Old Jan 24, 2012 | 01:42 PM
mporange's Avatar
Originally Posted by pauly_2
BHi Mporange,
Thanks
Pauly_2
You connect the speaker output to the amp and then the speakers to the amp. There is a bmw wiring kit that doesnt need to cut any wires.
But you have to pull some cables from the radio to the trunk.
See this http://www.e90post.com/forums/showthread.php?t=136594
Not an e60 but an e90 but the principle is the same.
Yes i am very sure of the 160mm subs in the low end system. I have not pulled my subs out. But it have been confirmed on many forums.
But you should be able to install an 8" sub. The small subs have a spacer.
sg530
Nov 6, 2025 06:06 AM
Michaeljl87
Jun 7, 2015 03:28 PM
tommyboy
Jun 6, 2015 02:45 PM
Mihainede85
Mar 11, 2015 09:45 PM
MrMack
Mar 31, 2004 07:33 AM
