attn 545i owners
Old 04-30-2009, 12:25 PM
  #31
vlad_b's Avatar
My Ride: 2005 BMW 545i Sport Package, Jet Black M166 OEM Wheels M5 Style Body kit RPI Scoop BMC Air Filter Valentine One Radar Detector 35% tint all around
Originally Posted by ivan545' post='864235' date='Apr 30 2009, 02:12 PM
my idle is around 500 that sounds right then, i only get that once in a while the slight rough idle, but i'll check out the SIB that is offered.
my car start's idling at about 800 rpm when cold then goes to 500 rpms and stays there. 500 rpm but sometimes it moves up and down by about 50 rpm.
when AC is on it idles at 750 rpm. i wonder if it's ok when th rpms go up and down slightly at idle
Old 04-30-2009, 02:28 PM
  #32
ivan545's Avatar
Made an appointment to drop off my car at the dealer monday, i'll keep you guys updated. See if they find anything wrong with the car i'll give them the SIB info about the idling. Might as well get this taken care of while it's still under warranty. But given the fact that the idling problem is not apparent or happens only certain occasions not sure what can be done. I'll keep my figures cross.
Old 04-30-2009, 02:36 PM
  #33
vlad_b's Avatar
good luck Ivan. let us know how it goes
Old 04-30-2009, 04:57 PM
  #34
tiangco.a's Avatar
Yea i had a rough idle when stopped between lights sometimes.
I cleaned my MAF and took out the secondary intake filter and now it seems to run great!
Old 04-30-2009, 05:00 PM
  #35
tiangco.a's Avatar
oh and mine idles around 750 all the time...a/c on or off...hmmmmmm
Also what fuel additives are you guys using?
Old 04-30-2009, 05:10 PM
  #36
Krozi's Avatar
I used the BMW brand additive.
Old 04-30-2009, 06:43 PM
  #37
miguex's Avatar
Location: Calgary, AB - Canada / Buenos Aires - Argentina
My Ride: 2006 BMW M5
I think 750 is quite high even when it is warm up..... I may be wrong. Around 500 is normal (in warm up and AC on) but yes 800/750 when it is cold. ..
like the others said, try: clean MAF, fuel addictive (Techron is the best IMO) but NEVER EVER use any OIL additive on BMW.
Old 04-30-2009, 07:29 PM
  #38
dirksqjaw's Avatar
My Ride: 2004 545i - Bone stock... help!
Originally Posted by Krozi' post='863125' date='Apr 30 2009, 12:47 AM
Interesting...
Well when my car is all nice and warmed up I would say that the idle is VERY smooth also, but not as smooth as, let's say a Lincoln town car, or a Lexus.
After a cold start my idle is a little choppy, but as soon as you ride a few minutes, the idle is quite smooth.
Yup. Warm up, you can tell (certainly not worrisome or anything) it's a bit rougher than, say.. when I make it to the first stop light/interchange. Only other time I notice any roughness is when I'm sitting in 125+ heat in gridlock traffic where the roadway is closer to 150 degrees, and I have the AC cranked.
Old 04-30-2009, 07:50 PM
  #39
nd1975's Avatar
My Ride: 2005 Titanium Gray 545i Sport, black leather, navigation, Logic 7, and no money for mods.
Originally Posted by vlad_b' post='862924' date='Apr 29 2009, 12:59 PM
how many of you experienced rough idle (slight vibration when car idles) on 545i or any other n62 engine?
I did some research and there is no certain fix to this. people switched spark plugs, adjusted walve lifters, used different gas, cleaned MAF, used fuel system cleaners, throttle cleaners, changed coils, airfilters, etc..
would be great if we can collect different opinions here and may be find the right answer. thank you
I have 26K miles on my and I notice that slight quiver when stopped at a light. Fortunately, it's so slight that sometimes I think I am imagining it. I brought it to the dealer for another issue and asked about a fix. He mentioned that BMW recognized the problem and heard at one time they were working on a software fix but because it would have to go through emission testing, they never finished it. I kind of thought that was BS and didn't push the issue - bottom line they weren't going to anything about it other than kick up the idle. Since my car abruptly slams gears when stopping from 10 miles an hour (the original problem) I passed on that solution since raising the idle would have made the transmission downshift condition worse.
  #40
doug_999's Avatar
My Ride: 2008 Sapphire Black on Black M5 - loaded sans soft close doors
To be clear, the issue is an occasional shake/almost stumble while at idle OCCASIONALLY. Have a friend who had an X5 with the issue. Dealer changed out the heads and the problem was better but every now an then it would do it. Caused him to dump the car - he drives a Tahoe now. I personally would have left it at BMW until they fixed it.
Quick Reply: attn 545i owners
