anyone know how to hook up a z4 sport button on a e60 pre lci?
Where's the 'like' button?
Now, for the switch, if your multimeter has a beep function and you can prove it works by touching the probes together and hear the beep, it should be no problem getting the NO contact figured out. Maybe if you had a friend over to hold the switch whilst you do the probing? Or maybe try again after a few Wotney's Red Barrel?
My Ride: E60 (LCI) M sport, Lane departure, Bluetooth, Xenons.
Engine: M57
You have the switch. If you do take it apart, take some pictures. In my world a switch has NO (normally open contacts that 'make' when you press), NC (normally closed contacts that 'make' when the switch is released). Other terminals for lights or indicators.
If this switch has no NO or NC combinations that you can find, you're either doing it wrong or the switch is opto-isolated or Hall. I wouldn't put anything past BMW - they sometimes use very strange technology.
Or you could try it with a good single malt Scotch.
Engine: M57
If it won't work can you please suggest something stronger, I mean more flammable pls?
My Ride: 550i
My Ride: 535
This is what it looks like when it's taken apart
![](http://www.unofficialbmw.com/images/sportmodeswz4.jpg)
It's similar to the buttons found in video game controllers and such where there's a conductive membrane that causes the resistance to change when pressed.
550iwa
03-27-2015 06:45 AM
BYS2
03-24-2015 03:13 AM
andymax
03-13-2015 10:51 AM
bapeforceone
03-11-2015 04:18 PM
