Anyone had this problem?
Old Nov 14, 2011 | 04:46 PM
pjinca's Avatar
I keep my lights on Automatic all the time, never had a problem.
Today I got home from work and it was getting dark so my headlights were on the whole drive, fine. I got home parked my car in the garage. I went to the garage about an hour later and I notice my taillights are on, I go around front and my AEs are on, but not the headlights. So I check the switch, thinking I had hit the switch with my knee or something (odd, but hey, I'm tall so it isn't unheard of). Nope, switch is still in "auto" mode. I turn the lights off manually on the switch and check, they are still on. I turn the car on and switch the lights to auto again, then I turn the car off and the lights are off.
I have no idea why they stayed on, it's not the battery - it's new I got it less than a year ago. Anyone else ever have this problem?
Old Nov 14, 2011 | 04:53 PM
nomis_nehc's Avatar
My Ride: BMW E60
Model Year: 2016
I think there was a member with this problem recently. Personally have never encountered it. Are you sure you didn't hit the turn signal stalk that does light up the appropriate side's parking light?
Old Nov 14, 2011 | 04:56 PM
pjinca's Avatar
No Simon, both parking lights and taillights were on. I don't recall if I hit the turn signal.
Old Nov 14, 2011 | 05:14 PM
545BlackinGA's Avatar
I've only seen it once and it was my driver's side tail. I just switched it to off and it went away. This was before I replaced the original battery.
Old Nov 16, 2011 | 03:27 PM
syrousd's Avatar
My Ride: 2008 550I,Space Grey,Hud,Cold Weather,M - Sport, matched GP Thunder headlights and Fogs,,Smoked Badges, Night Vision, Heated Seats,Rear Sunshades, Aux Audio, SAT, NAV, Black Grills, Sprint Booster, Dinan Cold Air, Stage 2 Dinan Software.....More to come soon
There is a relay/timer switch that might be faulty. I don't remember the exact location I need to look in my bently! I will look for it tomorrow!
Old Nov 16, 2011 | 07:38 PM
skripter2k's Avatar
I've had this problem before. I'm not quite sure why it happened but it was corrected when I turned the car on and off.
Old Nov 17, 2011 | 05:27 AM
545felix's Avatar
My Ride: 05 545/6
both sides (ie driver and passenger) were on? because if you hit the indicator stalk on your way out of the car, you would have turned on either the L or the R, but not both. they do stay on until you turn the lights back on/off or hit the indicator stalk again.
Old Nov 17, 2011 | 05:38 AM
pjinca's Avatar
Yup, both AE's and both taillights were on. Once I restarted the car and turned it off again, they went off and stayed off. It is weird. Hasn't happened since, and never happened before, even when the battery WAS bad.
Old Nov 17, 2011 | 05:57 AM
BlaSTiWi's Avatar
Somethin' similar happened to my friend, try this ... maybe it's similar to what happened to us...
With the light in auto start the engine get out close the driver door and go around then shut the engine off and take the key out from the passenger side.
In our case the dash, front AE & tail lights stayed on until I re-open the driver door.
Not sure if its a future or what and we didn't want to find out how long it stayed just worry it'll eat the battery
Old Nov 17, 2011 | 06:55 AM
545felix's Avatar
My Ride: 05 545/6
the auto lights do that until you open the driver door, but there is a timeout on it, i think it's 60 seconds.
gergnang
Feb 2, 2021 07:29 AM
bbbamboo
Sep 17, 2017 04:33 PM
RussHamel73
Jun 3, 2015 08:24 AM
gaz
May 29, 2015 06:11 AM
E60Japanese
Mar 23, 2015 05:23 PM
