Anyone add SIRIUS module to their E60?
Do you have CD changer prep in the glove box or trunk? The CD changer prep includes the power and fiber connections that you can use for the SAT radio. Any after market sirius type antenna can be used - you don't need to retrofit the shark fin or anything like that if you don't want to.
I have a SAT tuner I will sell to you.
The dealer will want a couple hundred $$ to enable the SAT or you can look for a forum member near year that is doing NCS Expert coding and they can enable it.
See my HD radio retrofit (in my signature) for related information.
My Ride: 2008 535i:
1992 Camaro RS:
DELETE
My Ride: 2008 535i:
1992 Camaro RS:
DELETE
Engine: N54
I have 2 available. Contact me via PM.
My Ride: 2008 BMW 535xi
After installing your receiver in your left rear trunk area, and changed the fiber optic cables, you can code the Car with NCSExpert. You need to add to the vehicle order (VO or FA on NCSExpert) $655 and delete $693 to the vehicle order. Once you process the unit and it's been added to your VO, you will need to Edit the CAPPL module and add the following to the file so it will show up on your Head unit as SAT:
SDARS
aktiv
After that the satellite receiver will work on channel 184 and a message will display to call a 1-888 number to activate the Sirius Service.
It's very simple to install and also code if you have NCSExpert and have learned how to code your car.
Hope this all makes sense.
SDARS
aktiv
Stormcrow
12-01-2019 02:09 AM
