Anti seize on lugs?
My Ride: 2005 545i | Titanium Silver | Sport, Premium, Cold Weather, Navigation packages | Style 124 staggered rims | iPod integration | Tinted windows
Hey Guys, can you please offer some advise here?
I swapped out my winter wheels and put my summer shoes on! Car looks great! But I noticed that the lugs were a little more stiff than before and they are turning brownish - almost like rust. Just wondering if I should use any anti-seize on the lugs? If so, what brand do you suggest and how much do I apply on each bolt?
I know that the dealer used anti seize on my E39 lugs, but they never did on my E60. I wonder what changed?
Also, can you please confirm, I torqued to 88 lbs. Correct?
Thanks!
Thanks!
I use anti seize on the hubs when installing the spacers, but not on the lugs....not sure if the lugs can get a little loose when using antiseize so....yea...
But 88lbs is right
But 88lbs is right
Properly torqued, the stuff should not cause or contribute to their loosening.
If you are concerned, use a drop or two of oil on the threads and wipe it down before installing.
I understand that lubricated threads can alter the "true" tightening torque of nuts and bolds but we're not talking about bolting down the hatch of the space shuttle here. IMHO, adding 5-10 ft lbs to wheel lug torque using a properly calibrated torque wrench won't cause a major problem. BUT. hammering them down with an air-gun - that's a way different story!
My Ride: 545i Sport
Engine: N62
BMWs current specification on M12 lug bolts is 88 ft. lbs. (higher for M14 bolts). This specification is with dry threads. Anti-seize, grease, or other lubricants on the threads of the bolt can, and will, artificially lubricate the threads, causing an inaccurate torque reading when using a torque wrench. This can yield a situation where the bolt is actually over-torqued (as shown in the case below).
Link.
__________________________________________________ __________________________________________________ _________
Link.
Happy otoring,
Joe[/color]
Thanks for your feedback / suggestions guys!
Vman33
03-14-2022 04:43 AM
trev0006
03-15-2015 08:26 PM
