Another tire question regarding 172
My Ride: 05-530i and 06 530xit
I have 172 rims {245, 35, 19(front) and 275 30, 19(rear) on my 530i with sport suspsension and toyo tr1 tires for about two years. I recently replace the my rear with falken tires fk 452 due to the cost factor {they were dirt cheap compare to the toyos}. However, after installing them my rear tires appear and look very small and strecthed. They leave a whooping gap between the wheel wells, and make my front look bigger than my rear. My question to everyone, do tires vary from different manufacturers, even though the specs are the same. I really debating of spending the extra cash and buy the toyos i had before. Any suggestion of how to make it look like they did before wider and taller. Thanks
The Falkens are known to be a bit "smaller" compared to other tires of the "same" size. A 285 Falken is about equivalent to a 275 in other models.
Originally Posted by e6t' post='931274' date='Jul 2 2009, 09:39 PM
which falken tires you talkin' about? you got these falken tires, those falken tires... i need to know which falken tires you got!
The 452's are what I am talking about. I am not sure if all Falken's run small or just these.
I have the falken FK 452--I believe I said that early-Can anyone reccomend and equally comparable tire to my toyos?
blackstarr
02-13-2016 08:34 AM
