All SMG transmissions the same?
My Ride: I have a 2007 Black Sapphire BMW 530i with SMG. It has the auburn interior, has PDC, Sports Package, Premium Package, rear automatic sunshades with manual side sunshades, 35% black tint, Upgraded angeleyes from Angelibrights, and Logic 7 Sound System
maybe you need a new clutch?
Damn bro, I am sorry to hear that this is happening to you. I hope everything works out and please update us on the progress so that us SMG owners can have an idea of what to expect. Thanks!
My Ride: 530i SMG
My Ride: 530i SMG
Today i managed to get the car in 1st gear but the car goes backwards. When i put the car in 2nd gear it jumps to N. I don`t think is the whole transmission. Reading on forums i`ve seen that numerous SMG owners had this problem and even if they changed the tranny the problem was still there after 1000+ km. Some of them fixed the problem by changing the salmon red relay, or fixing the smg pump motor, or slave cylinder.
Like this guy here:
https://5series.net/forums/dealer-pu...-ripoff-82563/
Btw, where is the salmon red relay located on the 2004 530i?
Like this guy here:
My Ride: 530i SMG
changed 2 relays today.....Salmon and Orange, not much changed (close to $100 from the dealer)
The only difference is that i can get the car in 1 but when i push the gas it goes backwards. If i put the car in D1 and i press the gas jumps to N. If i put the car 2nd jumps to N after 5 sec. Nothing happens if i try R, stays in N.
The SMG pump works fine, i can hear it when i open the car etc.
When i try to put the car in R, it sounds like something is trying to grab on to something else 4-5 times, after that it stops and remains to N.
Next step will be removing and fixing the slave cylinder : DIY: SSG / SMG Leaking Slave Cylinder Repair. - E46Fanatics
RealOEM.com BMW E60 530i GS6S37BZ(SMG) Actuator / Sensoren
Part number #13
also, checkout e46fanatic -- you will get ALOT more help there.
My Ride: 530i SMG
I believe I had this problem... take a look at:
RealOEM.com * BMW E60 530i GS6S37BZ(SMG) Actuator / Sensoren
Part number #13
Part number #13
Is there a way on testing the clutch position sensor?
I`ll try to get an audio recording of the sound that comes from under the car when i shift fron N to R and from N to 1.
My Ride: 530i SMG
Vocaroo | Voice message
Ok, so here is an audio recording of my transmission. Up to 30sec is from N to 1. After that you can hear it when it try from N to R.
Not the best quality...but better than nothing.
