Airbag and Seat belt lights on '05 525D
Old 10-04-2013, 06:28 PM
almandee26's Avatar
My Ride: 2004 BMW 545i sport package with Mteck & M5 Rims Mpower
Bobbyggx
Don't know if you can know but can you post a pic off your dashboard when you had the airbag light on ? Or did you have just had the airbag light on or airbag light with an passanger seat belt on as well ? Would like to know if that's the same problem I have or similar . PM me if it's better for you . Thanks
Old 10-04-2013, 06:31 PM
almandee26's Avatar
I just read the post again yes same problem I'll just do what you did as well see if it works for me
Old 10-05-2013, 10:20 AM
bobbyggx's Avatar
@almandee26,
This is a common issue (airbag and seat belt warning lights), so that might not be the problem in your case.
Post your errors in the different modules (SGM, STVL, STVR, SBSR, SBSL) and we can start from there.
In my case, when I was reading the statuses in STVL, SBSR, SBSL the RESISTOR DETONATION PILL was 0.80 Ohm which was below the minimum of 0.84 Ohm. I had errors in SBSR and SBSL (modules located in the pillar between the doors) stating that there is a problem with the communication with the door modules (STVL and STVR).
Old 10-05-2013, 01:36 PM
noberryafterdingl's Avatar
My Ride: stock e60
Originally Posted by bobbyggx
@almandee26,
i have both airbag and seatbelt lights on.... i drives says pass restraint system malfunction i pulled this code using inpa i do know how to code please help
Old 10-06-2013, 03:00 AM
bobbyggx's Avatar
Here is something you might find interesting.
https://5series.net/forums/e60-discu...ow-fix-129736/
DavaiLave
08-02-2022 02:16 AM
bimmermadness
04-24-2015 01:13 PM
rackhacker9275
26
04-16-2015 08:13 AM
shoryuken15
04-09-2015 03:42 PM
andrek
04-04-2015 08:47 AM
Quick Reply: Airbag and Seat belt lights on '05 525D
